Minilite wheels and spinners
Hi - I am trying to install my minilite wheels and have both the original spinners and I bought some center lock nuts and a big long handled spanner. Unfortunately the spanner bumps into the the spokes on the minilites. So what have others done to get around this. I gather there are three eared spinner tools that allow one to use a socket on the spinners, are there other solutions?
Thanks!
Thanks!
- Rall
Contact Lionel Roberts. His contact information is in this thread
viewtopic.php?f=43&t=30392&start=15
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
If you use Nuts like on +2S130 Elans you can use the big Anodised Socket.
These were made by someone on the Forum. They have a hole to put a Tommy Bar for tightening.
- alan.barker
I had this problem with a set of 'Minilites' I bought from Spyder. The wrench I bought from Sarto just could not latch onto the spinner 'ears' without contacting the face of the wheel and marring the finish.
My solution was to machine a set of spacers that nested between the spinner and the stainless insert supplied with each wheel. Worked well and have been in place for a couple of years now. I 'matched-marked' the wheel/spacer/spinner with black Sharpie dots so any relative movement would be easily seen - but none so far with 'spirited' driving.
'60 Type 14 Elite
'67 Seven
'70 +2 Elan
'72 Elan Sprint
'73 Europa
'83 Esprit Turbo
'60 Type 14 Elite
'67 Seven
'70 +2 Elan
'72 Elan Sprint
'73 Europa
'83 Esprit Turbo
- velo5338
I too have the same issue with my Minilites…..
I purchased my wheels directly from Minilite in 2018. The wheels were shipped with machined bushings that fit in the wheel center. I later became aware that RD Enterprises, http://www.rdent.com, also markets Minilite wheels, I contacted Ray and described my issue.
Ray noted that the wheels that he stocked provided ample clearance for the KO 3 Ear Nut tool to clear the spokes. We both assumed that my bushing rings must have been machined differently. Ray was kind enough to lend me one of his bushings for comparison.
I found that my OEM bushing rings were machined exactly like the sample that Ray sent …BUT the center of my wheels were machined deeper than the wheels in the RD Ent. catalog…the face of my rings are .125” Below the face of the wheel while the RD Ent. appear to be approximately .25” PROUD of the face of the wheel.
Ray also mentioned that he was aware of "Nader Safety" 3 Ear KO nuts. Ray emailed me a dimensioned photograph of a KO Spinner that he stocked. I found that my KO's Ear clearance to the base was .70” while Ray's was 1.125”.
So...... the ears of my KO Nuts are very tight to the Wheel spokes and unfortunately do not allow me to use the spanner to tighten the nuts. I plan to eventually have new bushing machined to solve the issue.
Attached are pics of my the Bushing Rings in relationship to the Wheel....
Rob.
Rob.
- Attachments
- MInilite Bushing Picture.pdf
- (133.18 KiB) Downloaded 312 times
- Goldrob
I agree with you.
However, here's four reasons I would, first two I've not experienced myself with the Elan's I've owned but have seen wheels with the damage noted:
1. cracking out to the locating pegs;
2. elongated locating peg holes;
3. to fit wider tyres with correct width rims to avoid unnecessary bagging of the sidewalls; and
4. If using the car for tracks days or competition, I'd not use a 50+ year old wheel.
Vaughan
Vaughan
- vstibbard
vstibbard wrote:I agree with you.
Vaughan
Vaughan,
If I could add to the above, the OE wheels are so thin, it's hard to find any that are true. The reason for the fatigue cracking is the flex during cornering on modern tires.
Dan
