+2 pinion stop dimensions
PostPost by: Hawksfield » Tue Jun 15, 2021 11:28 pm
Hi all
Does anyone have the dimensions of the extra piece welded on to the pinion lock nut as shown in the image.
The drawing in the WM is confused as it looks like it gives the dimension of 7.14mm for the lock nut. is this the spacer dimension?
I am in the process of rebuilding a good early Triumph rack to a +2 lotus spec I have all but the pinon end parts
Thanks in anticipation
pinion stop extension
+2s130 1971
PostPost by: pharriso » Wed Jun 16, 2021 12:56 pm
Per Mr Buckland....
Buckland_SteeringRackMods.pdf
(153.3 KiB) Downloaded 220 times
And:
Buckland_LockLimiters_TieRod.pdf
(539.92 KiB) Downloaded 210 times
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Hawksfield » Wed Jun 16, 2021 2:52 pm
Phil
Thanks for a quick response
+2s130 1971
