Question about front bearings and braking
Just double checking here - couldn't find anything via search. I'm assembling the front brakes on my S4 and the disk is binding hard against the inside body of the caliper on both sides. The disks look to be at least a millimetre off centre towards the inboard of the car. So, question is this: could the wheel bearings have worn enough to have caused this? They've done 64000 miles and are moving smoothly without any rumbles or binding.
JonB - Coveted Fifth Gear
The caliper mounting brackets are handed, can't recall if it's possible to fit them on the wrong sides but, if it is, maybe that's your problem?
S4 DHC
S4 DHC
- oldelanman
Jon
Have the disks been replaced?
I seem to recall that the discs on the S1/2 may have been different being changed on the S3/4, also the early calipers were again from memory changed to the later Type 14.
Its easy enough to pull the calipers and sheck that both sides are affected similarly and then to change the caliper mounting bracket to see if that resolves the issue.
Also read this previous post in the braking section Girling caliper measurement needed 16pb vs 14
Tony
Tony
- tonyabacus
Have you assembled the upright with the dirt shield between the upright and the caliper mounting bracket? This would move the caliper out by the thickness of the dirt shield (1.5mm??)
correct assembly sequence is upright/caliper bracket/dirt shield.
see here :-
https://lotuselan.net/wiki/CA_-_Front_Suspension
Brian.
see here :-
Brian.
- ncm
Should there be Spacer between Caliper and Caliper Bracket
- alan.barker
