Sprint brake master cylinder reservoir
I'm in a middle of a rebuild of my '72 Sprint mc and want to make sure the next time I do this, the reservoir comes off without drama. The part shown here, as you know, goes into the master and held with a 'ring in a groove' arrangement. Any suggestions for coating this ring and/or the bore in the mc with anything to keep the corrosion down, and provide easy ingress (egress in the future)? I'm thinking about using the red rubber grease provided but what do experts say?
Greg Z
p.s. As an aside, are these reservoirs being reproduced?
Greg Z
Greg Z
45/0243K Sprint
36/5727 pre airflow coupe
45/0243K Sprint
gjz30075 - Coveted Fifth Gear
Nice to see this picture, i try to remove the reservoir but it doesn't come off, i only can turne the reservoir. Whats the secrect to get it off without destroing?
- 1972 Lotus Elan Sprint LHD/DHC
- 1962 Austin Healey Sprite MK II - Sold 09.05.2016
Sorry for my bad survival English
mariodschy - Second Gear
Spray the hole in which the nipple of the reservoir goes liberally with a lubricant and pry upwards as evenly as possible, while twisting and turning. No guarantees. Unfortunately, a year ago when I posted this, no one answered so hopefully someone now will as to whether or not the reservoir is reproduced.
Greg Z
Greg Z
Greg Z
45/0243K Sprint
45/0243K Sprint
When I was looking for this part, northwestclassic.co.uk said they were getting some made.
In the end I cleaned up the old one and rebuilt it.
If they have got them back in stock I might get one for spare, let me know how you get on.
Jon the Chief
Jon the Chief
- oldchieft
I think I have 3 new old stock master cylinders complete with reservoirs which I want to get rid of - these have have horizontal mounting holes not vertical
I will post a picture tomorrow
- patrics
the reservoir comes off, it was not easy so i am happy to have it not destroied
Now i am searching for a rebuild kit but still whitout succes, did someone know a source for such repair kits?
The following two repair kits are working:
http://www.ebay.co.uk/itm/FORD-Capri-Mk1-1300-Tandem-Brake-Master-Cylinder-Repair-Seals-Kit-/221539011620?ssPageName=ADME:L:OU:AT:3160
and
http://www.ebay.co.uk/itm/BRAKE-MASTER-CYLINDER-REPAIR-KIT-FOR-LOTUS-ELAN-SE-SPRINT-USA-SPEC-1968-ON-/331494555678?ssPageName=ADME:L:OU:AT:3160
The problem with the reservoirs was fixed by puting in a o-ring as you can see in the appendix.
and
- Attachments
3-Tandembrakecylinder.pdf
- (179.75 KiB) Downloaded 202 times
