S4 dash loom
With the assistance of several forum electrical experts, I think I have virtually sorted my S4 wiring.
However, two niggling queries if anyone can assist.
Autosparks dash loom.
The column feed has a double green connector, I cannot see what attaches to this?
Secondly a black white wire from the centre of the loom, cannot work out what it is?
I should be very grateful for advice.
Peter
- cadwell
Green is general 12volt distribution feed, twin connector on circuit diagram shows most likely are
Hand Brake switch, indicator flasher unit, washer switch or to heated rear screen switch.
Black and white from heated rear screen switch to screen.
Have you the fuses in place.
may help
may help
- Craven
cadwell wrote:No they are dark green going into a double connector with nothing coming out
Peter
now that you're here, you may find some useful infos on the wiki (there have been some colorized pdf made for S4 as well iirc)
https://lotuselan.net/wiki/Wiring_Legend_for_an_Elan_S4
good luck !
S4SE 36/8198
nmauduit - Coveted Fifth Gear
nmauduit wrote:now that you're here, you may find some useful infos on the wiki (there have been some colorized pdf made for S4 as well iirc)
good luck !
Look in this thread https://lotuselan.net/forums/viewtopic.php?f=38&t=50455 for a colour coded S4 wiring diagram as a PDF file
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
