Elan Sprint (S4) legible Wiring Diagram
Good day Gentlemen.
Can anyone supply or point me to the redrawn Sprint (S4) wiring diagram referred to in various forum entries on this esteemed site please? Eyes are going, teeth and hair have already fallen out!
Bob
Bob
bloodknock - Fourth Gear
Bob
I have a copy printed in colour in A3 send me your address and I will post it to you, I am keeping the copy I had done in A2, I feel your pain trying to read the one in the Workshop Manual while holding a magnifying glass is no fun !!!
PeterExpart
New Forest National Park
Hampshire UK
Hampshire UK
- peterexpart
Do you have a copy center near you? In the US, we have Fed Ex (formerly Kinkos) business centers that numerous copy machines, etc, for this purpose. I took the one from the shop manual and they were able to blow it up to a readable size, then they laminated the copy. Easy to read and fingerprints wipe off
Greg Z
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
there is an electronic version of the s4 wiring diagram......somewhere.....
it used to be on here IIRC....not sure where now
I reposted Gareth Flanagan's wiring diagram in PDF format herehttp://www.lotuselan.net/forums/lotus-electrical-f38/wiring-diagram-t29157.html
There is also a modified diagram in 3 sections by Peter Wrisley, I really prefer this wiring diagram since it splits into the 3 areas & shows the wire colors, however the wiring does have mods:
These diagrams should be in the reference area or Wiki....
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Gentlemen,
once again I'm overwhealmed by the support you give to members. Thankyou very much everyone.
Here's one I made for myself, hope it helps
Dave
[code][/code]
Dave
[code][/code]
- Attachments
- Wiring Diagram.pdf
- (78.3 KiB) Downloaded 798 times
Lotus Elan Sprint
- sprint4dm
PaulJ wrote:I would also be interested in a copy of this or the other CAD drawing that is listed as this is no longer accessible on the site. There is a huge amount of work in this so thanks for recreating it and sharing what you have
Many Thanks Paul
Not sure why you are saying this, the PDF is still available in the linked thread https://lotuselan.net/forums/viewtopic.php?f=38&t=29157&start=
It has now been downloaded over 2000 times!!
Phil Harrison
Hi Phil
Its this one which is unavailable
http://www.lotuselan.net/wiki/Elan_S4_W ... _CAD_Files
Returns a file not found message, I've downloaded the pdf and its great especially at large print sizes for a standard car
I've modified the wiring and so was looking for a cad version that I could modify
Cheers Paul
Cheers Paul
- PaulJ
PaulJ wrote:Hi Phil
Cheers Paul
Send me a PM with your e-mail address & I can send you a DXF, DWG & Coreldraw version of the S4 diagram.
Phil Harrison
The time has definitely come when I must redo the wiring on my 1969 Elan S4. It was pretty chaotic when I acquired to car 30+ years ago and I have added to the chaos by adding new items such as more fuses and an immobiliser and doing quick repairs with new wiring.
There is barely any room left behind the dashboard which makes any attempt to access anything there very difficult and liable to cause even more problems. I would estimate that about only two thirds of the wiring is active and necessary.
I have not yet decided whether to remove all of the wiring and replace it wire by wire or to replace it with modern thinwall multiwires (in which case I would have to leave a wiring diagram for future owners when I am no more).
What is the experience of other owners who have done a rewire?
It would be of great help if I could obtain a CAD drawing of the wiring so that I can plan the rewire and record any alterations. I wonder whether Pharriso still has his CAD drawing on file and could let me have a copy?
Andy Coates
Andy Coates
- dandyc
