What Driveshafts do I have?
Hello all.
New to Elan ownership and am struggling to find what type of driveshafts I have installed. The boots have perished so need to replace.
I have attached a photo.
Thanks everyone
Thanks everyone
- Rcampbell5
It was a common conversion to throw away the rubber rotoflex couplings and replace with 2 UJs and a sliding spline. Many of the usual Lotus suspects still carry them:
https://kelvedonlotus.co.uk/product/drive-shafts-sliding-spline-track-day-33-bolt/
Personally, I am not a big fan as the splines lock up under load which can lead to issues. Having said that, Tony Thompson Racing managed to get them accepted for historic racing, and all the racing Elans I have seen use them. My preferred choice is to replace with CVs (although my racing Elan does have TTR UJs) - but as you already have them, I wouldn't bother changing.
The trick will be finding a supplier who uses the same rubber, the Kelvedon ones I linked to don't seem to, but I am sure someone will know where to get them.
Good luck.
Good luck.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Look to me like performance unlimited type or copy thereof due to the small coupling and adapter plates. No longer in business.
You can obtain motorcycle fork leg boots or gaiters of a generic nature and cut them to suit. Think i have even used steering rack bellows/ gaiters to protect.
![Very Happy :D](https://lotuselan.net/forums/images/smilies/icon_biggrin.gif)
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Hey thanks for your quick help/replies.
I will have a measure up of the existing boot and have a hunt around.
- Rcampbell5
I'm trying to use a similar set-up on my Elan, but having test fitted, found there really isn't quite enough clearance In the uj to give me confidence to use them on the road without some form of droop reducing system, either shorter shock absorber travel or "axle straps" to limit droop.
Anybody on here got pictures of their droop limiting device design please?
Are yours limited?
Are yours limited?
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
Being a complete newbie to Elan ownership, this is the first time I have heard of the droop issue. It doesn't look like I have anything extra added to the suspension. I'm unfamiliar with the rear shocks that are fitted as well. I will add a photo.
- Rcampbell5
We had these types of driveshafts made in batches for Triumph Stags if you speak to dave Mac propshaft at Coventry I am sure he will be able to supply some boots
Ian
Ian
- elansprint
Interesting. My 'new to me' S3 45/7286 has U joints installed by the first owner, probably some time in the
70s, do not lock up at full droop. The wheels turn freely. My other Elans with CV joints, are fully locked
up at full droop. I suspect the restorer of my S3 (previous owner) put in limiting droop Koni's. Now
I'll have to measure the droop for both cars.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
It is usual to have a small amount of grinding of the uj on both the shaft and plate side to prevent contact on full droop. If anybody has a photo of some Performance Unlimited shafts you can see the places to grind. This allows rotation at full droop.
Having had numerous sets of the new and old type made up in the past I have ground these areas.
There are plenty of Elans and Plus 2's driving about without short stroke rear shocks and without droop limiting straps. I did thousands of miles with my last Plus 2 with standard shocks. Long trips and vigourus driving. I don't think anybody under normal driving conditions is going to get airborne.
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
R Campbell and Philip,
Sorry, no photos but I have done this job twice.
Our shock absorbers were in good condition. On a friends Elan the shafts were soft steel so we shortened them by 25mm and recut the thread etc.
On my car the shafts were hardened so we could not have cut a new thread. Using a tipped tool, the top shoulder was cut back 25 mm and a tubular spacer made to fit under the nut to do the same thing.
Kelvedon sells a short version of the shocks for this purpose. This modification is not usually necessary on the Plus 2 which has a wider track.
Hope this helps
Eric in Burnley
1967 S3SE DHC
Hope this helps
Eric in Burnley
1967 S3SE DHC
- ericbushby
If it helps, I wrote an article on Doughnuts for the HLR magazine a few years ago, with descriptions of what was available. It is below.
- Attachments
2016 Spring Elan Doughnuts.pdf
- (469.03 KiB) Downloaded 126 times
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Anybody have pictures of the grinding /areas on the Performance Unlimited uj's, for reference please?
Philip
No sorry, but have done the job on a few Plus2 U/Js , ( one always has to carry a spare ) , just rotate one and let it "flop" and you'll see where they catch...
John![Wink ;-)](https://lotuselan.net/forums/images/smilies/icon_wink.gif)
Philip
That boot looks remarkably similar to that fitted to early minis here :- https://www.minispares.com/product/Clas ... 0to%20shop
Worth asking them for dimensions??
Brian.
Brian.
- ncm
Users browsing this forum: cliveyboy and 21 guests
