body number informations
That body number refers to one of the very early Lotus produced bodies, from early in 1964. At the time the last of the Bourne bodies were also being used on the production line at Cheshunt.
More on the attached articles I wrote some time ago.
- Attachments
- 2018 Jan Lotus Elan VIN Systems.pdf
- (1.04 MiB) Downloaded 250 times
- 2017 Oct Elan Bourne Bodies.pdf
- (1.23 MiB) Downloaded 246 times
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
trw99 wrote:That body number refers to one of the very early Lotus produced bodies, from early in 1964. At the time the last of the Bourne bodies were also being used on the production line at Cheshunt.
Hi Tim,
thank you so much for the links!
I was thinking early 1964 Thanks for confirming.
Is there anyone here that can give a more precise date when this body has been delivered and to whom?
- valerio
It was delivered, having been fully built by the factory, to Ets J et P Wauters, the Belgian Lotus distributor. The invoice date is 27 January 1964.
trw99 wrote:It was delivered, having been fully built by the factory, to Ets J et P Wauters, the Belgian Lotus distributor. The invoice date is 27 January 1964.
EUREKA!
here are other data:
Chassis Number 260313
Unit number 3286
Engine Number LP907
Can someone confirm?
I know that chassis and unit is not matching in some database but I know that in the lotus achieve there should be the correct data.
- valerio
Those numbers are correct for your car, as it left the factory.
