Steering Column
Has anyone had a similar failure to this?
An Elan+2S 130 was brought to me (on a trailer) with failed steering, on
examination it could be seen that the end of the top or steering wheel
section of the two piece shaft had sheared at the clamp which is fitted to
control the telescopic action required for crash protection ie the cut away
piece where the clamp fits down in the footwell. The shaft had snapped
completly off at the clamp, luckily when the car was being pushed (yes it is
a Lotus) my concern is has this occured to other cars and is this a failure
point?. The car had been involve in a minor accident to the right front and
while there was some body damage the wheel, a Lotus alloy, appears ok
although there are signs of slight damage to the tyre. Has anyone else had a
similar failure or can this be put down to the accident damage?
Steve Crook
Steve Crook
- Steve Crook
Hi Steve,
Have you had a good look at the fracture, is it a clean break or is there any evidence of a previous cracking which would indicate contributory fatigue failure.
The less-than -solid mounting of the short steering tube in the +2 does not help to avoid putting the shaft under stress at this point.
One reason I reinforced this area.
Sean Murray
----- Original Message -----
To: ***@***.***
Sent: Monday, April 14, 2003 11:57 AM
Subject: [LotusElan.net] Steering Column
Steve Crook
Sean Murray
To: ***@***.***
Steve Crook
Foxie - Coveted Fifth Gear
Hi All,
This is an area of the car where I consider the Lotus design is far from satisfactory.
In a nutshell, the steering column is a two piece affair with a clamp in the middle of it that allows the forward inner column to slide into the aft column tube on frontal impact. A clamp is used to allow this sliding action, while retaining the ability to steer the car.
The whole column assembly is mounted via the flexible joint at the steeringrack, then via a Triumph herald clamp to the top of the drivers footwell, and again via another clamp to a mounting bracket located near the dashboard. The mounting bracket is in turn mounted to the bulkhead.
i had several concerns with this set up in my Plus 2. The first is that the column does not follow a straight line between the rack and the mount closest to the steering wheel. The clamp into the top of the footwell was pulling the centre of the rack upwards, and this was putting unnecessary stress on the column. Lowering the column centre so that it ran straight meant that the studs in the clamp were no longer long enough to protrude through the footwell. The second concern was that the bulkhead and footwells were too thin and this resulted in excessive flexing in the whole assembly.
I solved this by mounting the column at the rack and by the clamp nearest the steering wheel, lengthening the lower clamp studs so that they would reach through the top of the footwell from a lower column position, and reinforcing then entire bulkhead with LOTS more glass. Finally, i replaced the rubber bushes in the upper column.
My column is now straight and almost rigid. This should eliminate unnecessary stress on the column. I could make the column rigidly mounted by strengthening the mounting bracket which flexes excessively, but thats a job foranother day.
Ray
-----Original Message-----
Sent: Tuesday, 15 April 2003 06:44
To: ***@***.***
Subject: Re: [LotusElan.net] Steering Column
Hi Steve,
The less-than -solid mounting of the short steering tube in the +2 does nothelp to avoid putting the shaft under stress at this point.
Sean Murray
To: ***@***.***
completly off at the clamp, luckily when the car was being pushed (yes itis
Steve Crook
This electronic email and any files transmitted with it are intended
solely for the use of the individual or entity to whom they are addressed.
The views expressed in this message are those of the individual
sender and may not necessarily reflect the views of the Christchurch
City Council.
If you are not the correct recipient of this email please advise the
sender and delete.
Christchurch City Council
http://www.ccc.govt.nz
Ray
To: ***@***.***
Hi Steve,
Sean Murray
To: ***@***.***
Steve Crook
City Council.
sender and delete.
- elanplus2
I purchased a 69' Plus 2 project car that had taken a substantial impact to
the LH front wheel. The inner column had actually twisted quite a bit from
the blow. The outer column was fine. Other damage included a bent frame at
the steering rack mounting location. Not sure if this is helpful info but
it's what happened to my car when it took a solid blow to the steering.
Sent: Monday, April 14, 2003 3:57 AM
- "Steve Holst"
My only problem with a fully restored +2 steering is that if the clamp slips
down a bit I honk the horn under hard braking!! One needs to leave enough
play at the top of column that small steering wheel deflections do not make
the horn contact.
The failure you speak of is really SCAREY!
Ken
'69 +2 with Cosworth BDR
the horn contact.
Ken
- lotuselan2
Hmm - isn't this the same setup we have in our "baby " Elans??? I never
did think much of that setscrew in the clamp business to hold the shaft &
tube together. George 67 S3 ( guess I will add checking shaft to list)
On Mon, 14 Apr 2003 19:43:37 +0100 "Sean Murray" <***@***.***>
writes:
Hi Steve,
Sean Murray
To: ***@***.***
on
to
away
it is
failure
and
had a
Steve Crook
writes:
Hi Steve,
Sean Murray
To: ***@***.***
on
to
away
it is
failure
and
had a
Steve Crook
- gobw2
thanks will have a look tonight and report back.
Sent: Monday, April 14, 2003 8:43 PM
Hi Steve,
fatigue failure.
Sean Murray
To: ***@***.***
away
is
failure
and
a
Steve Crook
Hi Steve,
fatigue failure.
Sean Murray
To: ***@***.***
away
is
failure
and
a
Steve Crook
- Steve Crook
