S3 SE sill trim and clips
PostPost by: gjz30075 » Thu Feb 01, 2024 1:06 am
I have one sill trim pulling away from the body so I thought I'd just pop off the trim, Using a plastic
pry bar made for popping door cards, I managed to pull out three of the clips from the sill itself. The
rest of the trim piece remained on the clips and it was a bugger to pop off. I thought this trim piece
was open ended to make it easy to slip on/off but mine is not.
I now read that this might be the MG strip and clips that seems to be touted here as the easy solution.
Pictured is one of the clips still attached to the body. Is this an MG part? Also, the strip does not have
the profile of the strips I've seen in other posts.
Is the solution simply longer rivets?
DSC02034.JPG and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: JonB » Thu Feb 01, 2024 9:15 am
That doesn't look like a Lotus clip. Or at least, not as the ones on my S4.
The clips are riveted through the fibreglass only, so longer rivets won't help. What you need are washers (of a sort - the hole needs to match your rivets) to put behind the fibreglass holes, in the sill. Pass new rivets through the fibreglass and then through the washer prior to popping. Because, I think your problem must be the fibreglass holes are worn and too large to retian the popped rivet properly.
PostPost by: elans3 » Thu Feb 01, 2024 11:03 am
Yes, that's an MGB clip.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
elans3
PostPost by: smo17003 » Thu Feb 01, 2024 11:50 am
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: gjz30075 » Thu Feb 01, 2024 2:23 pm
JonB, you're right. However access would require disassembly of most of the newly restored by the previous owner interior. My thinking on the longer rivet is there's more of the rivet to 'squish up' behind the fiberglass, hence, acting like a washer, of sorts.
I have a feeling the sill strip is also an MG thing and the Lotus clips may not fit it. I'll get some Lotus
clips and test. If not, I'll source a Lotus sill trim piece.
Thanks everyone.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: smo17003 » Thu Feb 01, 2024 2:57 pm
Hi Greg,
Try and get hold of some "peel" rivets. They open out like peeling a banana, so you wouldn't need to get inside the sill to use washers.
A longer rivet will need more force to pull it through, potentially damaging the fibreglass.
https://www.ebay.co.uk/itm/312334210194 ... 6s8QAAAAAA
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: gjz30075 » Thu Feb 01, 2024 3:38 pm
I like them, good idea!
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: Ianstuart » Fri Feb 02, 2024 7:21 am
Some time ago, another member posted this drawing of the correct sill trim.
If this isn’t what you’ve got, and if you’re concerned about originality, then this is what you need (plus the correct clips of course).
IMG_6318.png and
Ianstuart
First Gear
First Gear
PostPost by: gjz30075 » Fri Feb 02, 2024 9:46 am
Thanks Ian.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: skyarch » Sat Mar 09, 2024 7:14 pm
SNAP
I've used these, they're the male half of the snap that's on the windshield frame to snap the hood.
The trim then is approx. a little less that 1/32" from the body, but no more struggling with stock, or by now aftermarket, clips.
First attach the all the snaps and then track the trim onto them one by one.
snap.jpg and
skyarch
First Gear
First Gear
PostPost by: alan.barker » Sun Mar 10, 2024 7:10 am
smo17003 wrote:Hi Greg,
https://www.ebay.co.uk/itm/312334210194 ... 481-19255-
0&campid=5338723872&toolid=20006&customid=FI90ITIcAAAAxc-mnWjegOmr6s8QAAAAAA
PostPost by: JonB » Sun Mar 10, 2024 9:04 am
Does the trim have end caps?
PostPost by: gjz30075 » Sun Mar 10, 2024 9:15 am
^^^^^Yes. I ended up using what is on the car now (I think they're MG ones) and longer
rivets. I couldn't find the peel rivets in 1/8". I tried to slide the sill strip over the snaps,
beginning from the front, which required removing the wheel due to a small amount of
front to back curvature. I had to lift the end of the sill, due to the cap over each snap
but only got halfway. I ended up just 'snapping' the sill over the snaps with the heel
of my hand.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: tonyabacus » Sun Mar 10, 2024 8:29 pm
Try Howard at Bresco who provide a lot of old type fixings and parts, can't just locate his number but it will be on the Net
Tony
tonyabacus
