Umbrella handbrake mech restore
Hi all
I’m at the stage of restoring the umbrella handbrake on my S4. I can’t work out how it comes apart. I saw a nice thread that shows separation of the outer sleeve (press the recessed dot on the shaft). The handle appears to be aluminium (or mazak?) and I see a rolled pin for the white push button. I think, if I take this out the button will come out and I can spray the handle and shaft. Does the handle come off, if so, how? Any advice for getting the cable off, and the other guts?
JonB - Coveted Fifth Gear
Hi Jon,
First press in the little button then you can pull the handle and ratchet assembly out of the outer casing and detach the cable from the handle, remove the split guide at the lower end of the outer casing and you can then remove the cable. Dismantling the ratchet assemble is straightforward as far as I remember. The white plastic release lever pivots on a brass pin which is screwed into the handle.
S4 DHC
S4 DHC
- oldelanman
Thanks, that’s the picture I was about to post showing a screw head rather than a split pin. Thank heavens I didn’t have at it with a punch…
Now, for restoration I think a nice silk black paint will do the trick. Does the inner rod get a coat too?
Don't think I painted the internals .. just greased everything on assembly.
S4 DHC
S4 DHC
- oldelanman
When I refurbished one a few years ago, the internals were neither chromed or painted, but well greased.
'72 Sprint
'72 Sprint
- richardcox_lotus
Just finished Robin Read's excellent "Colin Chapman's Lotus" which relates another one of his "regulation wriggle rounds"
The regulations stipulated a "handbrake must be fitted" So he fitted a handle with a cable which directly pulled down the brake pedal !
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Users browsing this forum: rideaway and 13 guests
