CV drive shafts identification & boot replacement
PostPost by: holywood3645 » Mon Nov 20, 2023 1:20 am
Boot is split on my cv drive shaft setup.
I'm can't remember where I bought them years ago, but the boot is split at strut side. Anyone any idea what they are orginally off? As I need to find replacements
Also I've never done this on a cv shaft boot replacement before is it a difficult job?
James
IMG_9531.jpeg and
PostPost by: StressCraxx » Mon Nov 20, 2023 1:37 am
Hello James,
I'm almost certain the boots are from a VW Type 3 all the way through VW Rabbit and later transporters.
https://www.jbugs.com/product/86-1084-1.html
Or replace all 4 since they are all the same age and its a good time to relube them.
https://www.jbugs.com/product/9994.html
StressCraxx
PostPost by: h20hamelan » Mon Nov 20, 2023 1:56 am
Why did it happen?
I have a difficult time with the internals, holding things together, while installing boots.
Love your Mother
Earth
PostPost by: mbell » Mon Nov 20, 2023 12:23 pm
As stated probably VW. See https://www.jbugs.com/VW-Tech-Article-C ... Specs.html
To confirm which. I suggest using some aviation gasket sealer between cv and adapter plate and small bit of silicon under the corner of the bit metal cap to avoid any grease weeping out.
You'll also need a 6 or 8 mm triple square bit for the bolts.
PostPost by: alanr » Mon Nov 20, 2023 1:11 pm
Change it back to Rotoflexes..less hassle! :lol:
Alan.
Currently:-
1971 +2 S130/ 5speed Type 9.
PostPost by: alan.barker » Mon Nov 20, 2023 2:17 pm
If which it looks like your CVs Driveshafts have Alloy Adapter Plates you need Loctite on Threads + use Loctite Activator.
PostPost by: gav » Mon Nov 20, 2023 2:22 pm
Mine are Ford with 100mm OD on the CV housing and 6 bolts if that helps
gav
PostPost by: Hawksfield » Mon Nov 20, 2023 7:57 pm
They are on the net. ebay.
+2s130 1971
PostPost by: Andy8421 » Mon Nov 20, 2023 8:41 pm
alanr wrote:Change it back to Rotoflexes..less hassle! :lol:
Alan.
Less trouble with the boots maybe, but you will need to invest in a good club hammer to straighten out the damage when they let go at 75MPH on the M25....
32 Standard 12
Various modern stuff
PostPost by: gav » Mon Nov 20, 2023 9:27 pm
Ouch
gav
PostPost by: alan.barker » Tue Nov 21, 2023 10:54 am
IMG_20220831_173554.jpg and
IMG_20220901_163012.jpg and
It can happen with mm CVs if NO Loctite and NO Loctite Activator used on Cap Head Screws in Alloy Adaptors.
PostPost by: Andy8421 » Tue Nov 21, 2023 12:08 pm
Alan,
Thanks for this.
I am trying to figure out from the pictures what broke first. Was it one of the 3 large bolts that go through the adaptor plate, disc and 3 eared flange attached to the hub?
If so, I thought they had nylocks on them?
Any information would be very helpful.
32 Standard 12
PostPost by: Foxie » Tue Nov 21, 2023 12:21 pm
Alan.
When my last Rotoflex failed catastrophically doing a racing start from traffic lights, it also broke off the brake caliper completely, leaving me in the middle of a major junction with an immobile Lotus and a very red face :shock:
That's when I changed to CVs.
68 Elan +2, 70 Elan +2s
PostPost by: alan.barker » Tue Nov 21, 2023 12:42 pm
Andy,
It was the Caphead Screws that unscrewed because NOT Loctited. When Screws go into the Alloy Adaptors they need to be Loctited also with Loctite Activator.
Where the 3 Studs go into Ears at Diff or Hub they needed to be drilled out. They had been forced into their holes. In short a bodged assembly.
PostPost by: elansprint » Tue Nov 21, 2023 8:10 pm
CV joints are from ford Sierra with boots to match
elansprint
Next
