Rear shocks elan s3
I have a problem with my rear dampers. I’m installing my rear shock absorbes but I can’t tighten the upper washer. I have rebuild my old konis and bought secondhand rear uprights. Are the dampers too long? Are my Konis incorrect..
Diego
Diego
- Dieschelan
ill_will wrote:Hi Diego,
Is the gap symmetric side to side?
Yes is symmetric!
- Dieschelan
The fixing nuts vary between manufacturers because the dampers vary in size, but those supplied should be correct unless your housing is shorter than normal.
The type you need has a tube with the securing thread on the outside that fits between damper and the tube with a large washer welded on the top to press on the top of the damper. This washer has flats on its edges, or be hexagonal/octagonal to tighten it up. Here's one without a strut in the tube.
Shorter dampers just have a threaded collar to hold them down with slots on the top to tighten them.
Meg
