Differential out of alignment
I've just finished installing the differential in my new Spyder +2 chassis. I noticed that the differential is not centered so that the pinion faces down the middle of the chassis. It is off to the right and despite slackening off the fasteners I've been unable to swing the differential to the left to center it. Any ideas?
- mcole01
Mike,
I hope someone with more knowledge can help here, but I believe what you show is correct. If I remember correctly the design of the differential puts the crown wheel and pinion to the right hand side, and the prop shaft is offset to the right.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
The nose of the differential does not align directly down the center of the chassis if all is as it should be. It should be somewhat to the (vehicle) right side of center. However it should be parallel with the centerline of the chassis. Your photo makes is look somewhat skewed.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
RichardHawkins wrote:Mike,
Hope this helps,
Richard Hawkins
Plus 1
1968 +2 BRM
- Peter +2
