Electronic ignition using Ford EDIS and Megajolt
I am struggling a little with the wiring of the EDIS, which has 12 pins, two of which (2&4) are not used. Curiosity got the better of me, and I checked with a multimeter if these pins connect within the EDIS to any other pins. 2 connects to 11, which is the alternative tachometer supply. 4 connects to 7&9 both of which are earth (ground).
I asked the supplier “Trigger Wheels” if I could use 2 for an alternative tachometer supply, and 4 for another earth connection. The answer was “use the connections specified in the instructions” I was expecting a more comprehensive reasoned reply.
My electrical knowledge is very basic (I can wire a two way lighting circuit) and does not cover electronics at all. Does anyone who understands an EDIS know if I could use pins 2&4? My reason for asking is that this would untangle my wires a little.
Richard Hawkins
Richard Hawkins
- RichardHawkins
trying to recall which site has better info.
Many use EDIS, google should help. Lotus 7 chat as many use the Zetec and Duratec, Ford Mustang F body and most in the Volvo like on TurboBricks also any MegaSquirt or MaxTuning etc
Love your Mother
Earth
Love your Mother
Earth
You are very brave with limited electrical knowledge prodding a meter into connector pins of electronic devices I certainly hope the Mjolt was not powered up…
Bear in mind that 2 might go to 11 and 4 to earth in one power state but change when in another state.
I side with TriggerWheels on this one! As John shows, leave 2 and 4 well alone…
Hal Adams
Evora SR
Elan +2
Evora SR
Elan +2
HCA - Coveted Fifth Gear
Hal,
No power applied, EDIS not connected, hope I have not done any harm!
Richard Hawkins
Richard Hawkins
- RichardHawkins
I doubt that you have! But do be careful with these things!
Anyway, I tracked it down for you:
http://britishminicorp.chez-alice.fr/In ... ctions.pdf
Pin 4 you will be pleased to know is indeed an earth for an associated timing module whilst Pin 2 is a driver module signal that is a square wave 0 - 12v signal, probably attached to the same signal from Pin 11…
Hal Adams
Evora SR
Elan +2
Evora SR
Elan +2
Hal,
Thanks for finding that information. I don’t understand but then with my level of knowledge I should not expect to.
Connect screens to pin7 ONLY it is.
I also discovered that although pins 2&11 are connected,11 is a “clean” tachometer signal and 2 is a diagnostic signal.
Richard Hawkins
Richard Hawkins
- RichardHawkins
