Refurb alloy wheels
My alloys are possibly original, well at least 30 years old but in good condition just needs repainting. I've spoken to one place and he won't do them as thinks might be too much magnesium in the ally which would become porous if acid dipped and powder coated. Wondering what the concensus is and others have done as don't want to risk messing them up.
Alan.
Alan.
friedy - Second Gear
Have you considered vapor blasting for paint removal? Then mask, repaint with a good quality wheel paint such as Wurth. Then polish the bare metal with alu polish.
+1 a good wheel paint and for me not powder epoxy.
When i did a set for a 1973 +2S130 for the part hidden under Tyre i used a paint for alloy radiators.
Sorry to say this but the Hub and Spinner are fitted on the wrong side. You have fitted righthand thread Spinner on the left side of your car. On the lefthand side it should be lefthand thread. the Hub should have red paint for left side and green for right side. On Lotus Elans and +2 Elans they are the opposite to Triumph, mgb or Jags.
- alan.barker
Vapour blast then using a mini DA sander (I use an air DA with 2" pad) start with a 60 grit then work up to as high as you need to achieve the best possible finish. Then mask off the polished areas (time consuming but using a razor blade very easy to achieve perfect edges). Spray on a couple of coats of acid etch primer followed by a good quality paint. I have used VHT satin black wheel paint with good results. I have completed many sets of Dunlop D1 alloys using this method with very good results.
- 111Robin
Sorry i thought it was the front wheel
- alan.barker
I used these people for my wheel refurb over 10 years ago https://www.lepsons.com/
Admittedly the wheels were more modern Minilite lookalikes, but the finish was and still is amazing. They will do painted, diamond cut, polished whatever you want, I'm sure with their experience they would do a good job no matter what the wheel.
four wheels will cost you about £500 including removing and refitting tyres
Kindest regards
Alan Thomas
Alan Thomas
