Water Pump hole in block
PostPost by: pharriso » Thu Nov 17, 2022 11:42 am
Can someone tell me the diameter of the hole in the front of the engine block that the water pump fits into please?
KentBlockFront_waterpumphole.jpg and
TIA
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: jono » Thu Nov 17, 2022 1:56 pm
The water pump aperture is 60mm
PostPost by: pharriso » Thu Nov 17, 2022 2:04 pm
jono wrote:The water pump aperture is 60mm
Thanks Jono, that's 2.362"
Phil Harrison
PostPost by: jono » Thu Nov 17, 2022 4:50 pm
It is (I measured with a metric vernier).
PostPost by: alan.barker » Fri Nov 18, 2022 5:04 am
Hi Phil,
Why do you want to know dia of hole to nearest thou/.001"
Not bad for a sand casting lol.
PostPost by: pharriso » Fri Nov 18, 2022 5:45 pm
alan.barker wrote:Hi Phil,
Ah well this all goes back to a topic from 10 years ago https://lotuselan.net/forums/viewtopic.php?f=39&t=22662&start=0& since you asked....
An engineer friend designed his own cassette system based around the Burton water cartridge was concerned that the impeller of the pump was shrouded by the cast iron hole of the block & wanted to move the impeller more into the waterway in the block. Here is a photo of a standard Burton cassette out the back of a modified Lotus Twin Cam timing case:
IMG_9103.jpg and
He modified a Burton pump by extending the nose & also reduced the OD so the end of the cassette would go into the block casting:
IMG_9104.jpg and
Now I know the size of the hole in the block (2.362") I can see that the modified pump nose with an OD of 2.350" will fit into the hole, whereas the original pump nose OD (2.5" OD) would not.
I can now sit back & appreciate the cleverness of my friend's design (& wonder where I could find a longer pump bearing/ shaft assembly...)
The block may be cast, but the hole is machined. Aren't cylinder bores & all the bearing surfaces in the block machined within tenths of thous?
Phil Harrison
PostPost by: alan.barker » Fri Nov 18, 2022 7:08 pm
Hi Phil,
Yes and no, i don't think that hole is machined as "Chunky" would have to pay for that. Castings i think would be in general + and - .015" at least.
Cylinders and Pistons are one tenth of that and graded for size.
Users browsing this forum: lotusfan and 13 guests
