Help: Broken dellorto float pin pillar
Hi all. Disaster. I've managed to break the pillar that clamps the pin that holds the floats in my dellortos. It's part of the top cover cast. I was being really careful... but nevertheless I'm now not sure how to proceed. I can't find any stock of top covers in the usual suspects. At the moment I'm trying to remove the choke piston so that I can determine which variant of top cover it actually is.
Ok I've got the piston out now. I have the 14mm diameter version.
Does anyone have a spare top cover
I've just found that Eurocarb, bless them, have a repair service for £50! Hoorah! I've emailed them, have found the broken bit that pinged across the garage that camouflages things that drop onto it, and am ready send it off. Damn it I might drive it up there... not in the elan though, of course.
Regards.
Sean.
Regards.
Sean.
- alaric
JB Weld lasts...... for a while. Ask me how I know, from way back. Eventually, the fuel gets to it and it breaks again.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
Hi. Thanks for your replies.
I was somewhat despondent last night - like that time I got to the end of a very difficult piste skiing, and coasting to the bar fell over and broke my knee.
This morning I sent the top cover off to Eurocarb, after speaking to them. They didn't need the piece that broke off, so I think they are going to mill off the remains of the pedestals and fit a replacement part of some description. I'm intrigued to see what the fix is. For £50 I think it's worth a try. Hopefully it will be back with me later this week, or early next week, and I can get onto the next problem haha.
All the best.
Sean.
All the best.
Sean.
- alaric
Hi again all.
I have the top cover re-assembled, and have fitted the floats. All looks good so far.
But, the split in one of the pillars is now gone - which I'm actually relieved about. The pin is a loose fit in both holes. Given the pin can't actually go anywhere once it's on the carb, does this matter? Does anyone else bother making sure the pin is locked in position? It wasn't when I took it apart. Des Hammil's book suggests inserting the pin then using pliers to compress it, but I'm not doing that again - yes that's how I broke it - following his book! Although he does warn... my advice - don't do it!
So, is it ok to leave the pin a snug but not locked fit, retained by the side walls of the carb once the top cover is in place? I want to use something to stop it rattling - some sort of fuel resistant putty is all it needs I think.
What have others done about this?
Thanks in advance.
Currently I have nothing lost or broken.... hoorah!
Sean.
Thanks in advance.
Sean.
- alaric
That's a good idea. Thanks for that - it's obvious now that you've said it, like most good ideas. I must be honest that I'm quite nervous of squeezing the pin, though, as I don't have spare pins or top covers, and there's no going back. I think I'll give it a go though.
I still haven't preened the butterfly valve screws either. I was planning to deploy mole grips rather than a hammer, though.
Regards.
Sean.
Regards.
Sean.
- alaric
Alaric,
I would be inclined to use a pin that is a bit longer than standard, so that you are really sure it can’t slip sideways and jam.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
