Ask about Capo Insulation Pads
1 post
Queen Platform Bed Low Profile Review
If you are looking for a queen platform bed that is not unnecessarily tall, then a low-profile queen bed will suit your needs perfectly. These beds are ideal if getting into or out of high profile beds poses a challenge, or if you love your pets sleeping next to you, but they cannot jump.
Generally, people love low profile beds for the contemporary look they give a room, especially for a Japanese themed bedroom motif.
Low-profile beds give the room a spacious appearance since they are less bulky. They deliver a timeless minimalistic style.
Important Link: The Best Ways to Choose a Good Queen Platform Bed in the World
Here are some queen platform low profile beds to consider
#1. Aisling fabric queen platform bed
A good night’s sleep helps rejuvenate you for the day’s activities, Aisling fabric bed gives precisely this. Its upholstery is a beige-colored fabric that blends beautifully with various décor. The silver-tone headboard, which is 52 inches high, adds glamour to this eye-catching queen bed platform.
The slats which are framed in black coated steel eliminate the need for a box spring. The slat system is great because it cuts on costs. The foam padding ensures the mattress stays in place and minimizes noise.
#2. Waverly queen platform bed
Enhance your bedrooms look with this contemporary styled, low profile queen bed. The bed is constructed of solid hardwood and has sturdy legs. Moreover, the superb finishing of rich espresso veneer fits well with different styles.
With this particular platform bed, a spring box is not necessary. This bed takes a bit of time to assemble since it is a heavy-duty bed.
#3. Modway Elsie Modern Low Profile Metal Platform Bed
If you are keen on a minimalist design, then this would be a worthwhile consideration. The bed has clean lines, and its bed frame is versatile as it complements modern, contemporary, and rustic designs.
Steel makes this particular mattress foundation, and therefore, box springs are not necessary. One notable element is that the slats have a spacing of fewer than three inches and offer great support to your mattress to increase comfort.
The bed features a powder-coated steel slat construction for noise-free sleep. It has foot caps on its dowel legs, which protects your flooring. The inclusion of a center beam provides reinforcement and increases stability.
The bed comes in three color variations white, grey, and brown, which are friendly because this allows you to choose what blends best with your bedroom.
#4. Victor button platform bed
The bed has a classic design with nailhead trim and button tufts that make a bold statement. The smooth upholstery is filled with foam and is made from either brown faux leather or if one pleases white fabric. Not only does the upholstery scream of style but also offers comfort as you recline on it.
The nailhead trim along the sides accentuates the linear structure. The slat kit made in a European style provides a firm foundation for your mattress. The bed’s solid wood and veneer construction assure you of the durability of the bed. Take time to look at the https://platformbedexpert.com
#5. Hughes queen mid-century platform bed
It is a low-profile bed with an intriguing design that adds class to your room as a centerpiece. The design of the upholstered headboard is for plush comfort. The headboard’s fabric is beige, which neatly complements different designs.
Its support system is slatted, which allows you not to have a box spring for your bed. The walnut finishing of the wooden frame is perfection. The tapered legs offer a fresh look breaking the monotony of the block legs of most foundations. The bed is easy to put together and can be done in forty minutes by two people.
Manhattan queen bed frame
For a laid-back look that is easy to complement with other pieces, this bed would be great for you. The bed frame comes with a headboard for you who fancies headboards. The upholstery material used is faux leather. There is the padding on rich ebony leather.
Its frame has wooden slats that increase the cushioning as you sleep and lengthen your mattress’s life span. The simplified design of the Manhattan queen bed frame is easy to assemble and comes with all items required packed. The bed frame is an excellent pick because it is gender-neutral.
#6. Sarahi 10" Low Profile Heavy Duty Platform Bed
Sarahi is thoughtfully constructed and gives an overall chic look to your bedroom. Steel builds this bed frame and, when assembled, is guaranteed to be noise-free. The bed design is not suitable to use a headboard, which is critical to keep in mind.
It accommodates a distributed weight capacity of 1500 pounds comfortably. The bed slats are 3 inches apart, assuring you that your mattress is taken good care of. On shipping, the bed is neatly packed in one box to make its handling less cumbersome once it gets to you.
#7. Harney Solid Wood Low Profile Platform Bed Frame
This is a durable platform bed made from pine that adds a rustic look to the room. It is available in espresso, natural, and cherry colors, giving you the option of choosing what most excites you.
Solid wood makes the bed’s frame, and no plywood is required. It is incompatible with a headboard or an adjustable bed. Three center support legs are sturdy and allow them to accommodate a weight of 500 pounds evenly distributed comfortably. It comes with all tools required for assembly, which is convenient for you. It has a 5-year product warranty.
Conclusion
Shopping around, it is easily noticeable that there are many platform queen bed frames that is low profile. They are stylish and meet your needs. Be it to allow your young child to easily climb into bed or as a matter of a great liking to low profile beds, you are assured of finding something that will take your breath away. Be sure to note the details of the bed, for example, if you are keen on having a headboard is the bed you want to purchase compatible with one. Bring home a piece that will still have you smiling in years to come.
Conclusion
codypowers - New-tral
1 post
