Extra holes behind the tail lights?
reverse lights?
backing up alarm?
backing up alarm?
Love your Mother
Earth
Love your Mother
Earth
Lincoln62 wrote:Most early S2's had 4 round lights like S1's.
By the staining on the panel this looks like it had the Vauxhall lights like the later S2 or something similar.
+1
My car 4088 has S1 lamps, as did your 3984, and the Vauxhall lamps look much better so it's a likely upgrade.
Meg
I'm wondering if the added holes were for lamps for a UK license plate
It did come with a front plate that may have come from the UK.
https://lotuscorps.org/pictures/picture ... tegory/156
- zog
The C at the end means the car was first registered in 1965.
Keith Marshall
- saildrive2001
If they were plate illumination lamp holes, wold the inside lights not block the light?
Love your Mother
Earth
Love your Mother
Earth
h20hamelan wrote:If they were plate illumination lamp holes, wold the inside lights not block the light?
Yes, they certainly would. Perhaps the adjacent hole was blocked off and the outer lamp hole had a combination brake/tail/turn signal lamp?
StressCraxx wrote:I'm wondering if the added holes were for lamps for a UK license plate
Early (26 series) British Elans had a lamp like on the dash lamp centrally above the registration plate between the tail lamps. There must be pictures on the forum showing it (mine is not correct but in the right place).
USA export models had totally different lamps to UK, I believe.
Meg
There's no space to add a light to go within the existing lamp without severe butchery.
Could someone have added a lamp the other way around to act as a boot illuminator?
- Attachments
- vauxhall-victor-1.jpg (130.57 KiB) Viewed 690 times
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Could a previous owner added a small reversing lamp to each side. The pattern looks like some of the Lucas offerings similar to those used at the rear of +2s and MGBs
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
By size and position original 2x2 tail lamp setup S1 style replaced by Vauxhall cluster S2 style. The small hole for the outer lamp probably disapeared in the outer big hole.
The size of the small S1 hole is the same as the front indicator hole and fixings.
Anna
Anna
1965 S2
- Emma-Knight
Users browsing this forum: Kjmaloney and 9 guests
