Reconfigured throttle linkage.
While sorting out some fueling issues on my +2 I decided that I didn’t particularly like the feel of the throttle pedal, wasn’t achieving a constant idle position and wasn’t getting full throw with the original cable configuration. A bit of Amazon shopping and welding later the new linkage works really well.
- sabbot
nice work
Love your Mother
Earth
Love your Mother
Earth
Those are nice efforts. I had to struggle with mine, too. It was super fast to open nearly full, making part throttle an exercise in micro foot movements. And the standard "race" throttle system could not direct the cable in a linear fashion over the movement angle. So I made this:
(Sorry it's upside down!)
Sandwiched inside the rotating bit is an eccentric using an Euler curve. When the cable starts to pull it is pulling on the large diameter end. When it is nearly done, it is pulling the small diameter section. This helps to offset the unbelievably rapid rate of change in throttle area as the valve swings through the arc.
The rod end allows the path of the cable to remain tangent to the eccentric's curve.
It's funny how frequently people become dissatisfied with throttle mechanisms!
- baileyman
I have been admiring your handywork gentlemen.
I have started to think through this on this my LHD GTS project. Inspired by the writings of Carroll Smith (1), I have in mind a control cable running in a nice curve behind the dash, but started to run out of ideas for the actuation (I building my own pedals) although I had in mind the idea of running it under the Webers.
The top photo from Sabbot has the sort of rod bearing supports that I had in mind.
The "the rotating bit is...eccentric using an Euler curve" from Baileyman is a very good idea indeed.
This type of detail is very important for making a car easier to drive.
Andrew
(1) "Nuts, bolts, fasteners and plumbing handbook" (I have the 1990 version!)
Andrew
- Frogelan
I used a Mangoletsi kit on a previous Elan that had twin DHLAs
https://www.burtonpower.com/mangoletsi- ... p4245.html
butt there was nothing similar for Strombergs, hence the fabrication. The only real downside is that I couldn’t find small rod ends with left and right hand threads, which would have made it easier to balance the carbs.
- sabbot
