plus 2 wiring diagram
Hello there this is my first post on the site and are looking for some help i have been a triumph man up to now but have gone to the other side complete restoration on a plus 2 130s am well on the way But i am looking for a wiring diagram I have complete new loome ready to fit but my book i have are showing the wrong diagrams I am looking for a diagram for 1973 130s with a single fuse box in the center of the dashboard can any one help many thanks Dave
- lotusplus_2
Hi ,will have a look at the manual we have with our 130 and see if it has the diagram you need. Car is same as ours with centre box, but doesn't mean the workshop book is right for our car. Will check over the weekend and let you know. Cheers, Rob
- jasper2347
When I was playing with my '73 Plus 2 S dashboard Dave I had to make a 'physical' map of what wire connected to what connector on what switch to keep sane!
Also took a photo of it all connected up. It's quite high res so download it and you can look around at (most of) the terminal layouts, and with comparison with the physical map, it may start to make sense.
The dash is without doubt the complicated bit...the straight wiring diagram should sort you out for the rest.
If you are taking yours apart though do check the layout with the diagrams. Lotus wiring looms can have some variations, and of course, previous owners may also have their own ideas of what is correct!
At back of Workshop Manuel there are all the different +2 and +2S diagrams
- alan.barker
Really good idea. What software did you use?
Not many of the free ones allow wires with trace colours, but I'm using draw.io to reproduce the original wiring diagram (which I can create trace colours on), and then I can mess about with relays and fuses etc. Also it helps me "learn" the loom as I go.
Rapidharness is a good free tool for actual loom design but if we're just copying what's already there, probably overkill.
Ned
Ned
Elanintheforest wrote:When I was playing with my '73 Plus 2 S dashboard Dave I had to make a 'physical' map of what wire connected to what connector on what switch to keep sane!
+2S 1969 50/2283
NedK - Second Gear
I believe this is the diagram you need. It's the one that matches my s130 with dash fuse box. Not sure if it will be readable in this format or not.
I plan to create a spread sheet that lists all the wiring as basis if doing a custom look for my car to add various relays and support for ac. But probably years off finishing that at current rate.
- mbell
http://www.mossmotoring.com/lucas-wirin ... -approach/
Open this and follow the links it,s a very good insight to classic car wiring.
P.S All credit goes to USA64 for the original post.
George
Elan+2
Mk2 Mx5
Elan+2
Mk2 Mx5
- George S L
Having recommissioned my +2s130/5 (NPW866M, which I believe is one of the last press cars) earlier in the year after 10 years off the road, I decided to redraw the electrical schematic in CorelDraw, this enabled me to produce a pdf version which you can zoom up and get much better detail, or print without loss.
Hopefully I've managed to attach it OK, along with a jpg of it, as this is my first post
Keith
Keith
kmabin - New-tral
kmabin wrote:Hopefully I've managed to attach it OK, along with a jpg of it, as this is my first post
You have, and thank you very much for sharing Keith. Very helpful!
- mbell
https://www.classiccarwiring.com/ Has a nice big laminated color version. It’s nice, but I have a Plis 2 S and it is for a 130, which should suit you well. Better because it shows the wires in color.
1971 Elan +2S
1975 Elite 503
2005 Elise
1991 M100 (sold, regretfully)
1975 Elite 503
2005 Elise
- dcmarsh
dcmarsh wrote:https://www.classiccarwiring.com/ Has a nice big laminated color version. It’s nice, but I have a Plis 2 S and it is for a 130, which should suit you well. Better because it shows the wires in color.
It is also totally wrong....It shows the +2S130 as having a V8 distributor!.....I wonder what year that is suppose to have happened!...Interesting proposition though, a V8 in a +2
'71 +2 S130/ 5speed Type9.
- alanr
I think they use the same example image for all the diagrams. Rather than show each diagram, they probably worried about the image being copied which I can't blame then for. I'd be more likely to purchase if I could see the diagram was correct for my car given the number of variations.
- mbell
Yes having looked again I think you are right. The 'quick view' is just an example of all diagrams. Like you say though with the different variations used on the Elan+2 it would fill me with more confidence to buy if I had seen a specific diagram example for the car I wanted it for.
Alan.
Alan.
- alanr
