Dash Fan switch problem, rocker type
Has anyone got a spare switch I could buy?
The high speed position on the Elan fan switch started not to work, I removed the switch cleaned up the internal contacts, reassembled, tested it and found a bad connection where the spade connector Is rivetted, see photo... It’s slightly loose, enough to stop the fan running.
I can’t see how to reliably tighten or replace the rivet... any ideas?
FYI - the fan switch is exactly the same on the 130/5 dash.
Iain
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
is it an original switch or a repro? I believe the original ones can be dismantled (probably not too many times), which would enable to inspect the inside for carbon deposit (quite a bit of current in the fan), and possibly tighten the rivet thanks to both side access.
other than that, soldering (like for electronics) ? watching out for plastic damage, I would use a large soldering to have enough heat capacity and heat quick and out, before too much heat is transmitted to the plastic. I see some oxidation (greenish color), application of reducing contact grease may be of help, too...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Thanks Nic,
It's an original, I guess it has had the wiring detached a few times and so the pulling and pushing the wiring on and off would loosen it. I did fully dismantle and clean up the internal contacts springs etc... then found the loose spade connector later.
I suspect the solder will not hold if the contact has movement, so I may try dismantling again and squeeze the rivet up - but it doesnt look too strong to me.
Iain
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
Looks like that rivet has ben peened over more than once..
Johns right, comparing to another switch the rivet has been squeezed up before so that’s not an option.
For interest I ran the fan full speed direct from the battery at 12.6v and it’s pulling 5A = 63 watts.
(Slow speed pulls 3.5A)
If I can get the switch sorted should I put a relay on the fast speed? otherwise the switch runs hot.
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
lotusfan, thanks I hadn’t thought of that one, maybe a last resort...
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
Users browsing this forum: nmauduit and 13 guests
