Can I use a modern Digital DWELL & TACH
Hi I was wondering if I can use a modern Digital DWELL & TACH on my Positive Ground Lotus
example is a BTMETER BT-770K..Louis Lottner
Elan S2 1965 #26-4840
Colin Chapman’s immortal words ‘Simplify, then add lightness’
loueelotus - Second Gear
That looks like a nice kit. I have an Actron (private label cheap consumer chinese bosch) and it works great.
Thanks for the info.. Now that is will work .. Do I connect the positive red to the ground and negative to power (Distributor) as in the old models of dwell gauges..
Lou
Lou
Louis Lottner
loueelotus wrote:Thanks for the info.. Now that is will work .. Do I connect the positive red to the ground and negative to power (Distributor) as in the old models of dwell gauges..
Lou
Yes.
Thank you for your help..
Love the saying **There is no cure for Lotus, only treatment.** absolutely right on my man..
Lou
Lou
Louis Lottner
