Battery Earth in boot
• Page 1 of 1
Having seen a few comments on the proper location for locating the battery ground in the post about diff mounting, I thought I'd comment:
I've owned a few Elans over 35 years, and all came with the trunk mounted battery grounded to one of the rearmost body mounting points at the bottom of the boot floor. So I'm pretty sure this is the way they left they factory.
It is also, IMHO, probably the worst possible place to ground any part of the electrical system. The rearmost holes in the chassis are "though" holes (no thread) so the ground between the chassis mounting bolt and the chassis is based on having a good bare metal connection between the bolt head and the chassis. Then the usually plated steel bolt passes through a threaded pot metal bobbin to which one attaches the earth cable with a nut. It all works until you actually start using the car and after a couple of years the bare metal connection is rusty from puddles and car washing and any oil dribbling from the engine or gearbox have further increased the electrical resistance at this joint. The bobbins also can corrode, if one is using a non stainless fastener, further adding to issues.
So on every one of my Elans I've fabbed a new ground cable to attached to one of the welded captive nuts (cleaned with a tap, then nickel or aluminum based antisieze) of the diff rubber mounts, using a stainless stud with a spacer to raise the cable to approximately even with the body panel (makes it easier to remove, if needed). Sometimes a bit of fiberglass removal is required to get clearance.
Then no more concerns, ever, about electrical grounding in the rear of the car. Similarly, I use the threaded body bolts behind the dash and into the front shock towers as proper grounding points in those parts of the car.
Here's a photo from my current project: (the spacer will be shortened to about body height after final install)
Cable terminal then clamps between the two nuts, with current carried by the stainless stud.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
- Third Gear
Lotus recognised this at some point in the +2 production and moved the battery earth to the strut brace behind the seats. The aerial was earthed to the diff mount on some +2. That looks nicely made
1968 Elan plus 2 - project
2007 Elise S2 [modified with a Hethel 70th sticker (yellow)]
2000 Elise S1 - Sold
- wotsisname
- Third Gear
Thank you for your very informative post and photo. A very elegant solution indeed.
I'm not planning to put the battery in the boot but this can be recycled elsewhere in the car as earthing/grounding is a question that I had not yet found an answer to.
Andrew
Andrew
1965 Lotus Elan S2 26/4022 (originally Dutchess Lotus East, PA and NJ Area, USA)
- Frogelan
- Fourth Gear
In a plus two that solution will be difficult with the Fuel Tank
Alan.b Brittany 1972 elan sprint fhc Lagoon Blue 0460E
- alan.barker
- Coveted Fifth Gear
alan.barker wrote:In a plus two that solution will be difficult with the Fuel Tank
Indeed. Luckily my original chassis earth seems to be good but definitely worth maintaining, or investigating alternatives that could employ a similar upgrade.
1970 Elan Plus 2 (not S) 50/2036
2012 BMW R1200GS
"It just wouldn't be a complete day if I didn't forget something!" -Me
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
• Page 1 of 1
Users browsing this forum: MartinH and 11 guests
