dellorto carbs
This is what i found when i took my carbs apart.Any thoughts on what to use to clean the jets.
George
George
George
Elan+2
Mk2 Mx5
Elan+2
Mk2 Mx5
- George S L
If you know someone who repairs clocks then Horolene is excellent for brass or steel parts. Soaked overnight and they are good as new.
It is too expensive for a one off job. Well, it would be for me !
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Thanks for the info guys,just had a suggestion to try vinegar
George
George
George
Elan+2
Mk2 Mx5
Elan+2
Mk2 Mx5
- George S L
Try vinegar (or anything else) on a piece of scrap brass before risking your carb parts. You can buy new emulsion tubes but it would be a shame to wreck them.
- mikealdren
Vinegar is great on steel.
I soaked an old carburettor for a Hillman Minx and it pretty much disolved it.
I would not risk any parts of your carbs to vinegar.
I sent mine away to be ultra sonically cleaned and overhauled.
I'm pretty sure I had the recommendation from someone here on the forum. I must have done it about three or four years ago now, the cost was very reasonable and they look as good as new today as they did when I got them back from the refurbisher.
It may take me some time, but I will try and dig his contact details out for you.
Jeff 72 +2
Jeff 72 +2
jeff jackson - Fourth Gear
That was quicker than I thought:
Chap I used was:
Paul Hollidge
Weber Carb Reconditioning Services
http://www.weber-carbs.co.uk
[email protected]" target="_blank" target="_blank
07976 985477
I have attached photos of my carbs after cleaning.
Reagrds
Jeff 72+2
Chap I used was:
Paul Hollidge
07976 985477
Reagrds
Jeff 72+2
Thanks guys,after seeing Jeff,s carbs thats the the way to go, been looking for company near me and I may even buy a cleaner 3L tank ?50-?70 so not to pricey and one carb should just fit.
George,
George,
George
Elan+2
Mk2 Mx5
Elan+2
Mk2 Mx5
- George S L
Drop them in a gallon of cellulose thinners and leave for a week. Then re-grease the bearings work better than most methods.
