S1/S2 door lock fitting problem
PostPost by: 661 » Sun Aug 05, 2018 11:21 am
Are there 2 lengths of Austin Cambridge door opener? Mine seems too long. What am I missing?
I have 4 locks and all appear the same size.
The button appears proud..
but the lock appears in the right place
and there's no way the button will sit at the right height once the handle is in place
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: types26/36 » Sun Aug 05, 2018 11:44 am
I dont know the answer to your question but here is a pic of my S2 locks
s2-locks-002-copy.jpg and
types26/36
PostPost by: 661 » Sun Aug 05, 2018 12:08 pm
Thanks Brian.
That's quick and very interesting
The single nearside catch I have is longer! The chrome bit that sticks through the handle doesn't really matter if its a bit longer, it's the barrel that's critical.
so I have 2 options:
Buy a new nearside lock, or scavenge the barrel mechanism from one of the 3 offside locks I have.
Has anyone ever dismantled these successfully ( to grease them etc)?
The other dimension to check would be the handle depth. There will be a gasket depth to add to it.
Graeme
S4 SE
S2 GTS
Caterham 420R
PostPost by: types26/36 » Sun Aug 05, 2018 12:39 pm
Well one looks ok .....my barrel approx 38mm (see pic)...... close to yours.
Do you have key locks on both sides? the rear ones for the Cambridge dont have key lock so just wondering if those are a different length?
PS I see your vernier is in the same state as mine :lol:
s2-locks-003.jpg and
types26/36
PostPost by: 661 » Sun Aug 05, 2018 12:42 pm
The long one has no lock.
The 3 offside locks are a mix of one lock and two without, but all the same length...?
I've just taken the chrome locking mechanism out of one of the offside locks, I wonder if the barrel is TIG-able?
I could cut it down and re weld at the correct length.....
Graeme
S4 SE
S2 GTS
Caterham 420R
PostPost by: 661 » Sun Aug 05, 2018 4:31 pm
Well, it's not weldable.
Certainly meltable at 25Amps!
Graeme
S4 SE
S2 GTS
Caterham 420R
PostPost by: Frogelan » Sun Aug 05, 2018 4:36 pm
Hello Brian and Graeme
I have just measured my locks in the same way as Brian and have a figure of 38.5mm.
This comes with the following warning: I have not got round to trying to fit them...and they are "fresh from the scrapyard".
I hope you will post more cases of your gremlins...;-) they are very useful reading!
Frogelan
PostPost by: 661 » Sun Aug 05, 2018 9:21 pm
The only thing you have to remember with new parts is 'nothing fits'.
It all needs fettling
The doors are a disaster. Even the simplest things just don't fit.
Admittedly I'm a bit anal.
The scissor lifts just score the inner door skin so I reglassed those with recesses.
I think I'll take the door catches apart and change the barrels over. I will be able to anodise the outer plate then too
Graeme
S4 SE
S2 GTS
Caterham 420R
PostPost by: Frogelan » Sun Aug 05, 2018 9:29 pm
Graeme
Out of interest, where did you buy your "scissors" / other door parts ?
Frogelan
PostPost by: 661 » Mon Aug 06, 2018 9:20 am
Frogelan wrote:Graeme
The scissors are TTR, made from steel. I have seen the ali ones from Kelsport and I would say the TTR ones fit better!! I'll get them anodised before final fitting
The ali door handles are a race item from Dave Hughes, the locks are from ebay(original), the window channel stuff and lock plates are all TTR, as are the plastic windows.
The doors are TTR
The inside door handles are original from a member on here
Graeme
S4 SE
S2 GTS
Caterham 420R
PostPost by: batfish » Mon Aug 06, 2018 1:36 pm
There are definitely 2 different lengths of locks in existence. I bought one from one of the well known old parts suppliers some years ago and it was like yours way to long for the door handle.
regards
Andy
batfish
PostPost by: Frogelan » Mon Aug 06, 2018 1:41 pm
Andy / Graeme
Thank you for these gems. Have either of you bought / found new lock barrels (ie just the interiors of the S1/S2 locks).
Andrew
Frogelan
PostPost by: batfish » Fri Oct 13, 2023 1:57 pm
Just to update on the lengths of the door locks, the longer stem ones are from the Vanden Plas Princess/ 4ltr.
Andy
batfish
PostPost by: Frogelan » Fri Oct 13, 2023 2:33 pm
Thanks Andy!
Frogelan
PostPost by: 661 » Fri Oct 13, 2023 3:43 pm
Holy thread resurrection, Batfish!
Graeme
S4 SE
S2 GTS
Caterham 420R
Next
