Fuel line to Chassis clips
PostPost by: pharriso » Mon Oct 16, 2017 9:34 pm
What are people using to clip the nylon fuel line to the top of the chassis tunnel these days?
Lotus originally used "Omega" clips 036L6003:
I have checked with Sue Miller, SJ Sportscars & RDent who have nothing; Matty sells generic "P" clips:
Another alternative is these BMW pipe clips which appear perfect in size:
bmw_2333206_3.jpg and
BMW Part # 2333206
What did / would you use?
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Certified Lotus » Mon Oct 16, 2017 10:57 pm
I have been using steel P clips with rubber molding on all my rebuilds for the fuel line. I also add a clear piece of tubing around the tubing at each of the clips. I know, I?m totally over doing it......
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: Orsom Weels » Tue Oct 17, 2017 7:31 am
I've used these on more than one occasion,
0024046_8mm-fuel-or-brake-pipe-clips-pack-of-5.jpeg and
They work well but you sometimes have to slightly open the holes in the chassis for them to clip in.
They are available here, https://www.carbuildersolutions.com/uk/ ... pipe-clips
They also have lots of other options.
Regards, Tim
Orsom Weels
PostPost by: pharriso » Tue Oct 17, 2017 10:22 am
Thanks Tim, they appear very similar to the BMW clips.
Phil Harrison
PostPost by: oldelanman » Tue Oct 17, 2017 10:53 am
Button head cable ties perhaps.......
S4 DHC
PostPost by: nmauduit » Tue Oct 17, 2017 3:07 pm
oldelanman wrote:Button head cable ties perhaps.......
easier to use these with the body off I guess...
S4SE 36/8198
PostPost by: oldelanman » Tue Oct 17, 2017 3:19 pm
Impossible without ...... probably :(
S4 DHC
PostPost by: Elan45 » Wed Oct 18, 2017 5:34 pm
Since I will not use nylon fuel line (absolutely NO fire resistance), I replace the plastic with copper line. I then use the aircraft P clips that are made from metal w/ the rubber cushion on them. My S3-SS has over 30 years this way and my Coupe restoration will have the same very soon.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
