5-Speed gear lever notch
PostPost by: Foxie » Sat Oct 03, 2015 8:28 pm
I was doing a bit of modification today to the gear lever in my Ford T9 gearbox in the Plus 2. The fork on the T9 seems exactly the same as the Lotus Maxi type 5-Speed.
There is a notch on the right side of the selector fork, see pic.
On my gear-lever, the main shaft of which is cranked to the rear, the notch is on the right-hand side.
However I have another gear-lever, which I got as a present, where either the gear lever is cranked forward or the notch is on the wrong side.
Has anyone any idea of the purpose of this notch, and will the gear-lever work if it is rotated 180 degs ? :)
PA030297.JPG and
68 Elan +2, 70 Elan +2s
PostPost by: ort » Sat Oct 03, 2015 8:36 pm
the notch goes on the right hand side. it's clearance to allow reverse gear to be selected
ort
First Gear
First Gear
PostPost by: Foxie » Sat Oct 03, 2015 9:13 pm
ort wrote:the notch goes on the right hand side. it's clearance to allow reverse gear to be selected
Ta ! That makes sense.
That's the second thing I learned to-day ! :)
PostPost by: Foxie » Sat Oct 03, 2015 9:20 pm
I also found out the plastic pivot ball can be pressed off and on again, enabling the shaft to be heated and bent, or cut and welded to get best position
PA030297.JPG and
PostPost by: gjz30075 » Sun Oct 04, 2015 5:52 pm
Just to confirm, it looks to be the same orientation when used in a Lotus 5 speed box, correct?
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
cron
