Wiring diagram
Hi Shaun,
I have one, but I wont be able to copy it until Thursday, if that's OK.
Just to confirm though, it is a UK car?
Kind regards
Jeff
Kind regards
Jeff
jeff jackson - Fourth Gear
Is it the 3 fuse box version or single, and do you have a dynamo with voltage regulator?
- carrierdave
Hi Shaun,
Attached is the wiring diagram for the +2s with the three fuse boxes and dynamo.
The changeover is quite easy, if a little daunting at first. There are 3 or 4 cables in the dash that need to be joined together (from the amp and ignition I think). Then I retained the regulator but run a link across the back. there are two earth's (black) and two small brown & yellows that need to be joined at the regulator. I also changed from a amp meter to a volt meter.
There are many links on the web to sites where people have converted to an alternator.
Good luck and if you need any help just shout.
David
David
- carrierdave
Thanks for the drawings Jeff,is there any chance you could email them to me as I'm struggling to make a copy thanks Shaun [email protected]
- shaun
Hi Shaun,
Email sent, let me know if you received the document OK.
Kind regards
Jeff
Kind regards
Jeff
