Washer location on rear A arm to hub carrier bolts
• Page 1 of 2 • 1, 2
I am installing the rear a arms after replacing the bushings and wonder where the washers are fitted on the hub carrier to a arm bolts. There were only washers at the contact point of a arm bushing and carrier. Should I place washers at the bolt head to a arm bushing contact? Also just behind the nuts? Most all areas where bolts contact the aluminum housings have a washer to distribute load.
Greg
Greg
'67 s3 SS
'72 +2 S130
'72 +2 S130
- Greg Foster
- Third Gear
I have poly bushings and have washers on the outside (bolt head end). When I did not have washers there, the bushings drifted out under hard driving conditions. I used to have washers on the inside (nut end) when I had rubber bushings, but with poly bushings there is a bit of a lip on that side that resulted in not enough room. I would rather not grind down the aluminum housing to make room for a washer as that seems self-defeating to me. All the best, Dan
collins_dan - Coveted Fifth Gear
Thanks Dan, Rohan.
I installed rubber bushings and have the washer both in and out . If I install wider wheels, it seems I would have to remove the outer washers on the hub carrier to a arm bolts. But that is not happening now.
Greg
Greg
'67 s3 SS
'72 +2 S130
'72 +2 S130
- Greg Foster
- Third Gear
I'll be refitting my rear wishbones this weekend after fitting new bushes so would like to clarify this point.
- It's pretty obvious that there needs to be a washer to be at A.
- A washer at B seems to be uncertain. On my car I'm pretty sure that there's going to be no room when I come to put it together. There were no washers before and I don't think the new bushes will have changed the situation. However, Section R "Final Drive", Section R.2, "To replace" Step 2 on Page 5 refers to having a washer at B: "Reconnect the left-hand wishbone, ensuring the spacer washers are located between the wishbone and the bearing housing." It's clear that having one would protect the hub but, as Dan says, there's no point in grinding the hub away to make room for one.
- A washer at C also seems uncertain. I don't think I've ever seen washers there, and with Panasport wheels the clearance between the head of the bolt and wheel is so small that a washer might prove impossible. If Rohan's good without a C then so am I, but if I was using the original steel wheels, which have plenty of clearance from the head of the bolt, then I guess I'd use one per Dan's comment.
So I predict that I'm going to end up with just A. And sleep well?
Nick
Nick
elanner - Fourth Gear
No washer at C
There is no need for a washer and insufficient clearance and the already specially thin head can touch the inside of the wheel.
Washers at B depend on clearance created by the shape of the wishbone and the position of the bush.
Washer plus any spare washers at A so that the next bloke has the correct washer.
- AHM
In my experience, you need a washer at C if you use poly bushings, given how easily they move within the housing.
Dan
Dan
collins_dan wrote:In my experience, you need a washer at C if you use poly bushings, given how easily they move within the housing.
Dan
I have penny washers at C, but they're a slightly smaller diameter than the poly bush, in your experience should the washers cover the bush and A frame tube?
Mazzini - Coveted Fifth Gear
I think mine might be a little smaller as well and work fine. The main thing is that the bolt head is too small and the bushing crept out over it. I settled on the ones I am using because they covered the bush almost completely and didn't catch the wheel. Dan
Isn't this something that should just be settled by the workshop manual?
I don't have mine to hand but I am sure there should be four washers per side fitted against the faces of the aluminium hub carrier. Definitely no washers under the already thin bolt heads.
If you've changed the original design by fitting Poly bushes all bets are off!
Regardless though, I would say that there should still be washers against the aluminium faces, to spread the concentrated load caused by the small area of the bush sleeves. If you find there is no room for washers then something is wrong with the assembly. It is normal to have to 'squeeze' the washers in with the metalstic bushes.
If polybushes need large external washers to stop them moving axially then something is wrong with their implementation from a design POV! One of the functions of the wishbones is to restrain the suspension against fore and aft movement and bonded metalastic bushes perform that function perfectly. If that function is done by a washer bearing against the bush housing then surely that assembly should be lubricated?
I'm sticking to bonded bushes.
Ian
Ian
68 Elan S4 DHC. Built in a weekend from a kit (just like the advert said)
Elanman99 - Fourth Gear
As shown in the early parts manual although not shown in the later w/s manual or parts manual.
Brian
64 S2 Roadster
72 Sprint FHC
64 S2 Roadster
72 Sprint FHC
types26/36 - Coveted Fifth Gear
In what feels like a coda to this post about washers on rear A arm to hub carrier bolts, I seem to have an unanticipated result when rebuilding my '67 S3 suspension. See the attached two pictures.
Pretty obvious that on one side (driver's side) the forward bolt is "too short", and on the other side (passenger) the two bolts are "too long" and actually touch when the nuts are screwed on.
I replaced the bushings of course--with new standard bushings from RDent.
Does this mean that on the driver's side I need to grind down the bushing that is making the bolt appear "too short", and on the passenger side I have to insert a washer here or there to keep the two bolts from meeting?
Thanks as usual!
Jeff in Chicago
p.s. car moved for the first time under its own power in 53 years!
67 S3 DHC
- chicagojeff
- Second Gear
Users browsing this forum: No registered users and 29 guests
