Plus 2 window mechansim spring
To remove the motor and levers, I unbolted the motor from the lever arm and most know what came next! The spring popped off the lever and only caused a small cut on my hand.
My question is how much does the spring have to be "pre-loaded" before installing on the lever? I know the function of the spring is to adjust for the weight of the window so that it will go up and down at about the same speed (slow and a bit slower but that is another story well posted on this forum). I can easily pre-load the spring a half turn by manipulating the lever and using a vice-grip. Is that enough? How would you turn it more before fitting?
Ken
Ken
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
DavidLB wrote:Workshop manual shows a pair of holes that when lined up on the operating levers to hold the spring in tension 1/4 bolt I think will do the job
That's how I did it, but can't recall details. Might have shoved a screw driver in the holes. Window taped in the up position. Have a magnet wand ready to fish the fasteners out of the door when dropped.
Stu
1969 Plus 2 Federal LHD
Will check shop manual, DUH!
Ken
Ken
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
Hi Ken
Been there did that as well!
with the plate off the motor I recall I held the blade in a vice then rotated the plate until the spring looked like the other motor's spring and then used a bolt to hold the plate to blade in tension while I reassembled onto the motor
Have attached a picture of the spring on my other motor as its out of the car at present
Hope this helps best of luck
Bob
Bob
- bob_rich
Bob
If I get this right, you do not need to add an extra rotation to the spring which would be a real task. I put plate in the position that would give the least tension and then forced the spring on with a screw driver. All changes in plate position would be higher tension. I think I got it! Next weekend will tell.
Ken
Ken
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
Hi ken
I am going from memory but I think it is about 1.5 turns. I put the blade in a vice held near the far end so the plate that holds the motor could rotate through a full 360 degrees ( Motor was off 4 this) The spring is put on so that it is unwinds on lift and tightens on lower. I put the spring on with the plate over the blade and then turned the plate a bit over 1 turn until I cold drop a bolt through from the motor side to lock it in position. then fitted the motor and then the holding bolts could be removed. I used garden gloves and turning the plate through a full turn and a bit was had but not unreasonable.
I have another thread on a related subject as I am reassembling my passengers door at present
Bob
Bob
- bob_rich
bob_rich wrote:Hi ken
I am going from memory but I think it is about 1.5 turns [... I used garden gloves and turning the plate through a full turn and a bit was had but not unreasonable. [...]
Bob
Well. I beg to disagree. I managed to turn the spiral spring about a half-turn +45 degrees from idle until the arm lined up with the motor support bracket. Then I tried to add another 1/2 turn to see if I could add more pre-load but no. The spiral spring was so tightly coiled over itself that it blocked before the half turn was reached. (You can try in 1/2-turn increments because there are 2 positions at 180 degrees where you can locate the spring)
François
Fran?ois
Lotus Elan Plus 2 130S Big Valves
LotusEngineeringBuff - Second Gear
