Steering wheel removal
PostPost by: SteveC » Sat Feb 16, 2013 2:21 pm
Can someone please advise how to remove the steering wheel on plus 2.
I removed the horn push expecting to see a nut, but no. Take a look at photo
image.jpg and
SteveC
First Gear
First Gear
PostPost by: oldelanman » Sat Feb 16, 2013 2:38 pm
SteveC wrote:Can someone please advise how to remove the steering wheel on plus 2.
It looks to me like you have removed only the button from the centre of the horn push, the body of the assembly is still in the wheel boss. Prise that out and you should then see the retaining nut.
S4 DHC
PostPost by: john.p.clegg » Sat Feb 16, 2013 2:39 pm
Gently lever out what is left of the horn push and you will see the nut below...
John :wink:
PostPost by: GrUmPyBoDgEr » Sat Feb 16, 2013 2:44 pm
Oh dear!
It appears that the components of horn push have parted company. (It's fallen to bits!)
I think you will have to find a way of removing those parts of the horn push from the steering wheel & re-uniting them with the parts you already have in your hands.
Do your best to get that bit right because replacements are not cheap or easy to find.
Anyway, by now you should be able to see the large hexagon nut that keeps the steering wheel onto the serrations of the steering column.
Good luck
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: GrUmPyBoDgEr » Sat Feb 16, 2013 2:46 pm
john.p.clegg wrote:Gently lever out what is left of the horn push and you will see the nut below...
John :wink:
Very quick there John but simply missing my eloquence :lol:
T'other John
GrUmPyBoDgEr
PostPost by: SteveC » Sat Feb 16, 2013 4:55 pm
Thank you for all the advice.
Wheel is off and prepared for reprint. Once painted, should the paint be covered in clear lacquer ?
Also for the aluminium wheel spokes, any advice on cleaning them? Again lacquer finish coat?
I'll post end results when done.
image.jpg and
SteveC
First Gear
First Gear
PostPost by: SteveC » Sun Feb 17, 2013 11:49 am
image.jpg and
End product
image.jpg and
SteveC
First Gear
First Gear
