twink oil filler cap
• Page 1 of 1
Hello, my oil filler cap aint shiny anymore, the mettalic string is broken. Any advice to make look it good again.
I might be able to solder back in place the string to its plate.
But what about the ternish look of the cap...?
Cooled down by CliveyBoy!
Pistacchio sprint 72 - Fourth Gear
You can polish it on a buffer, or get a beautiful screw-in cap from Ray at Rdent.com - only $49.
No interest other than a satisfied customer, though I don't have his filler cap on either TC engine!
RogerFrench - Fourth Gear
The retaining wire is probably stainless steel and therefore would be difficult to solder - you could use a crimp-on electrical ring terminal and remove the coloured insulation sleeve.
I think the filler cap itself is also stainless steel - at least mine looks to be - if that is so it should clean up with metal polish.
Roger
S4 DHC
S4 DHC
- oldelanman
- Coveted Fifth Gear
oldelanman wrote:The retaining wire is probably stainless steel and therefore would be difficult to solder - you could use a crimp-on electrical ring terminal and remove the coloured insulation sleeve.
Exactly what I have done on mine
rgh0 - Coveted Fifth Gear
thanks for the tip.
I will try to do so.
these caps are kind of expensive!
Ok done!
But the chrome finish on the cap seems unrecoverable...
Have you tried buffing it on a wheel? Something like http://www.anvilfire.com/FAQs/motor_buffer.php
I've just checked with a magnet some old caps that I have in stock and some are stainless steel ( non magnetic) and others with less nickel content (magnetic) With stainless caps they will normally polish up well and their appearance is usually only spoilt by dents and scratches as oposed to a deterioration of the finish . However some of the oil caps on later engines were electro plated. I'm not sure of the exact electroplating process but they were certainly of an inferior quality and it does show after a period of time. The surface corrosion and tarnished finish does not polish out.
You can just prepare and spray paint this type of oil cap using a can of wheel silver or similar paint and the appearance is much improved..
As for the wire, there is a gentleman on ebay who sells new retaining wires with a soldered on eyelet (listed under Lotus Twin Cam parts) and they are supplied with instructions on how to secure the plain end of the wire into the cap. Its a rather cunning and simple idea. You bend the wire tightly back on itself about 3/4 inch from the end and with a pair of pliers crimp the bend tightly together. If you then try and straighten the wire with your fingers it wants to spring back into place. It's this action that retains the wire in the cap!! You simply open up the wire as much as you need to so the end can be inserted in the centre hole of the cap, push it in hard past the kink in the wire and when fully home it springs back into place within the cap and this stops the wire from being pulled back out.
Nick
PS If they're not listed at the moment and anybody wants one, I'll get him to put some more on.
Nick
- avro
- Second Gear
I Will test mine With a magnet but i think i already know the answer...sadly.
Well I'm blowed....all this discussion about oil filler caps and one appears on ebay Nothing to do with me.
items-for-sale-f34/oil-filler-cap-t27421.html
Roger
S4 DHC
S4 DHC
- oldelanman
I contacted another ebay seller.
http://www.ebay.co.uk/itm/New-Oil-Fille ... 25784d9e67
And it's plain aluminium... but no hole nor wire.
• Page 1 of 1
Users browsing this forum: No registered users and 31 guests
