Bonnet connections on an S4
Hi everyone. This is a great forum and I'm happy to have a question for you. I've recently started restoring my '68 S4 Coupe. When I got the car the bonnet fixings were non-existent. Not having ever seen an Elan in the flesh doesn't help. I've bought the following parts from Mick Miller Lotus: 1x bonnet spring, 2x skid plates, adjusting bolt set and spring clips. I'm aware that I may need to glass in a strengthening ar of some kind to the underside of the bonnet itself. Now I just need to know how and where these bits all go. Any photos would be helpful
S4 Elan FHC 1968
Vyvyanovich - New-tral
Hi and Welcome.
Sorry I cant provide photos as my Elan lost its original setup before I bought it almost 40 years ago. The Lotus Club in Qld has a number of nice Elans which have their original arrangements so you should be able to some in the flesh.
I am sure others here will be able to provide photos also.
First off there is a bit of info if you use the search function.
Here are a few by using bonnet latches
http://www.lotuselan.net/cgi-bin/search ... oom_sort=0
bonnet catch
also has a few
Here are a couple of photos of My S4 Coupe\
There are some under bonnet photos at
elan-f14/bonnet-catches-t15156.html
that may help too
Good luck
Gary
bonnet catch
also has a few
that may help too
Good luck
Gary
Vyvyanovich wrote: I'm aware that I may need to glass in a strengthening ar of some kind to the underside of the bonnet itself. Now I just need to know how and where these bits all go. Any photos would be helpful
Greetings,
That subject has had some fairly recent coverage. I hope these threads help until you see one in the flesh. Photos are included in them.
elan-f14/bonnet-metal-hoop-when-was-introduced-t24719.html
elan-f14/bonnet-spring-hook-t23362.html
Skid plates: Aluminium strips pop rivetted to bonnet to give a bearing surface against the heads of the bolts.
FWIW My S3 had plastic bolts/nuts similar to number plate fixings which seemed a good enough "bearing"...but I'm not sure if they were original.
Cheers - Richard
- ardee_selby
Wow. Thanks for the speedy replies! Luckily the release catch set up is all functional
S4 Elan FHC 1968
