Getting OGU roadworthy again
Here is a photo of the standard adaptor (from Q.E.D) for the capillary bulb of the engine temperature gauge versus the enlarged adaptor that was made for me (I think by Vegantune of Spalding) when the water valve corroded the rear-most hole in the thermostat housing of my old cylinder head and it was cured by making the hole larger and cutting a larger thread. The larger thread is (I think) 1/2 BSP, anyway it's the standard thread of many plumbing fittings such as taps and especially the usual compression fittings for 15mm copper plumbing pipe.
This larger adaptor was too tight on its inner diameter and caused me lots of trouble because the sensor bulb seized inside it.
The strange thing is that who ever made it up, didn't really need to, because a brass thread adaptor from 1/2 BSP to 3/8 BSP is available as standard in plumbing shops. I bought this one in B&Q
The original adaptor (now lost) plus the brass thread adaptor would have solved the problem and due to its larger inner diameter would (hopefully) not have siezed around the sensor bulb.
In B&Q I also found a 3/8 blanking cap (I think 3/8 BSP) which fits onto the adaptor in place of the sensor bulb and would make it easy if necessary to run the engine without the sensor bulb inserted.
Well it seems pretty sure now that my fuel smell in the cabin was indeed caused by seepage through the long rubber pipe (braided with stainless steel mesh) that was fitted back in 2001. I have now replaced it with a hard copper-nickel pipe and the fuel smell has dramatically diminished, though I will not know for sure until I take the Elan out on the road and have a significant draft through the cabin to remove the old lingering traces of fuel smell.
Fitting the pipe was difficult, because it has to be gently bent and straightened in sequence to pass it down past the drivers knee side, then under the door sill then up in the cavity on the right behind the drivers seat (where I also have a loudspeaker for the radio) then finally across just under the parcel shelf trim and finally into the boot to connect with the electric fuel pump mounted on the cross-support.
The copper-nickel line is fastened to the trellis rods with cable ties after first wrapping self-almalgamating rubber around the pipe to prevent rattles.
I used PVC braided pipe to connect to the fuel pump, because the pump outlet was a bigger diameter than I expected and I have become worried about the bio-fuel ethanol content of modern petrols might damage nitrile rubber pipes. I tried to use the PVC pipe for the front flexible connection too, but the fitting on the fuel pressure regulator was too narrow and I could not get it to seal.
Just a note to say I haven't done anything to my Elan over the Christmas/New Year break, other than finish fastening in the right hand side panel and door seal and putting the driver seat back in.
Waiting for warmer weather, because I will have to do the flexible brake pipes out in my yard in the cold, not enough room in the garage.
Still waiting for warmer weather. It's being mighty late this year. Right at the moment it is snowing here in North London, UK.
So the only thing done for my Elan so far this year is that I have had 4 hard brake pipes made up, to go from the junctions to the 4 flexible brake pipes at the wheels.
Today was the first day that the Met Office did not forecast showers, so I started on doing the brake pipes.
Grrr, not a successful day at all.
I couldn't undo the old hard brake pipes for the front wheels, from the 5-way junction, the spanner was clearly going to round-out the hex flats on the union, which would have been a big problem, so I decided to leave the old steel pipes in and just fit the new HEL flexible pipes.
I did the right front brake OK, but I've had a minor disaster on the left front brake. The bleed screw simply would not unscrew and it has sheared off flush with the calliper surface.
I've taken the calliper off and tried to drill out the broken bleed screw, (trying to catch all the swarf with lotsa grease) but the enlarged hole is not perfectly central and now jams the drill each time so I can't as yet get the broken stub out. Can't remember where I've stored my stud extractors (those tapered things with a coarse left hand thread). Given up for today, disconsolate.
Anyone got any good tips on this issue?
Been there a few times over the years...so I feel your pain. These are not threads you want to be compromised in any way, so once you reach the vicinity of the thread on one of the sides (when drilling slightly off centre, as you now are) I'd be inclined to start worrying it with a small punch or other suitable sharp implement. The idea being to split the remains of the bleed valve threaded section thus allowing it to come away from the sides (ie reduce its diameter) and then get "turned" out once the pressure's off the threads. a bit of heat might help.....Never had much success with extractor studs myself.....
And then of course run a tap down the thread when the nightmare's over.
- robertverhey
...and watch the seat at the bottom.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
I'm relieved to know that someone else has encountered & fixed the problem. i.e to really know that it is possible.
I was thinking it would have to be done on a rigid milling machine that would be able to recut the hole in the screw centrally.
Has anyone else dealt with a sheared off bleed valve?
Does anyone know if Classicar Automotive can fix it for me? Will they accept a caliper with a seized bleed valve as an exchange unit?
billwill wrote:Has anyone else dealt with a sheared off bleed valve?
Yes, yes, and yes. I'll fix most things but front calipers just aren't worth the bother when classicar automotive will do a much better job for a sensible price.
You get your old unit back plated, new pistons, seals, bleedscrews.
- AHM
Hi Bill,
I have just done business with Lee at classicar automotive. Found him to be very helpful. I dropped off my car's calipers to them when I was over in Feb. He told me that my fronts were different types. One early and one late. He has matched up a pair from his stocks. Also, a PO had fitted a bolt instead of a bleed nipple on one of the rear calipers! He has repaired this and fitted new handbrake linkages from Kelsport (A necessary purchase unfortunately). The total price, including shipping these heavy items to Ireland, was very reasonable. Lee was easy to talk to and, as you can imagine, very knowledgeable. Found out that the rear calipers are shared with the Fiat 1500. I'm sure everyone here knows that but I didn't!
Hope that helps. Good luck!
Pete
Pete
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
- Bombay Racing Green
Info about brake pipe fitting on my car is on the following thread:
lotus-suspension-f42/tightening-flexible-brake-pipes-t28382.html
I have now dispatched my caliper with the sheared off bleed screw to Classicar Automotive for reconditioning. Lee Cherry there seems to think he will get that stuck screw out, whereas with days of WD40 soaking, and moderate torque with a stud extractor and moderate heat with a blow lamp would not shift it for me. To be sure of not damaging the thread in the caliper for the bleed screw, I would be inclined to rigidly bolt half the caliper to the bed of a milling machine and cut the old screw out carefully, but I have no such precision machine myself.
I had no such problems with the other 3 calipers, but having fitted new hard pipes of Copper at the rear, I have changed my mind and decided to fit Kunifer (copper-nickel) pipes instead, so I've ordered a set of those, plus some proper flange nut spanners.
I've also ordered a bunch of rubber boots for ball-joints as one on a track rod end has split.
And I've ordered (on ebay) a second-hand fuel safety inertia switch to put in my electric fuel pump circuit. I've realised I should probably have ordered one that the salvage person had taken the 3-pin plug connector from the loom of the dismantled car as well as the switch as the photo of the pin arrangement that I've seen looks as if that plug is difficult to obtain alone.
My Shiny, My shiny, muhahaha!!
My reconditioned front caliper has returned from Classicar Automotive; now nothing (?) stopping me getting my Elan ready for MOT. test.. except rain & cold.
I insured for the road yesterday.
Brakes were done & bled by last Sunday, then overnight I remembered I had forgotten to oil the trunnions!
So Bank Holiday Monday, had to jack the front up again. Then I found my grease gun is not capable of generating enough pressure with thin oil, so I had to refill it with grease and grease the trunnions instead.
Then the rest of Monday was applying T-cut to remove all the various dark marks accumulated over 3 years. I haven't finished that yet, done about two thirds. Then after that I will need to re-wax it to protect the now naked paint.
I re-did a wiper blade, so I think that the only thing needed for MOT test is to check all the bulbs work, that the horn works and pack all the tools from the passengers footwell into the boot.
Other commitments mean that I probably won't be able to get it to an MOT test before this weekend, but hopefully early next week.
Users browsing this forum: No registered users and 41 guests
