Restoration of 26/0086 unit 3067
After only 30 years in my possession I have at last found enough time to work on the total restoration of chassis no 26/0086 Unit no 3067
First registered 05/09/1963 as 3XBF. Bourne body no 26/0073
I did the chassis and engine some years ago, (they may need attention again by now) but have just made progress on the bare shell Resprayed to the original Yellow. It has also been red and black in its life.
Wiring and interior to follow. I think making a loom is the next job
rodlittle - Third Gear
Seeing as crash pads are made of unobtanium there seems no option but to make my own.
I am going to try by making a foam core then covering it in lightweight glass cloth then covering that in leathercloth so here goes
Progress so far
Now got to wait till the glass cloth arrives.
Progress so far
Rod,
Looks like you are well underway and looking great. The dash pad looks like it should work out also. I still have a couple of pads which are in reasonable shape which I will try to do some repair.
I like the fact you chose to paint down into the engine bay as it in my mind looks more complete that way.
Keep us posted as you move forward.
memini55 - Third Gear
Looking good, Rod. Is the car in Sunburst Yellow? If so, it's the same colour as my Elite, and I'm in a quandry....whether to paint it as original, or go for the slightly more yellow Jaguar Primrose, which is what most folks do.
The engine bay for your car, being such an early one, was originally grey-pigmented bare fibreglass, but I guess you knew that!!
Actually its in LO7 still listed as a colour in our local paint suppliers
and yes I did know the engine bay should be grey. Ive sprayed it a grey which is pretty near the rest of the body colour ( had to graft a new front on)
Being unsure just how far down the engine bay they were originally painted body colour, I decided to paint down to the flat above the pedal box on the bulkhead
the rest of the bay which of course you cant see in those pics is indeed grey.
Heres the foam core glassed over ready to cover in leathercloth, thats the really difficult bit, dont know how Im going to stretch it over those curves and get it to stay there.
if anyone has any ideas on this apart from heating it up please let me know.
Now covered in Leathercloth, turned out OK I think
Rod,
Your restoration looks great. On the crash pad, although leather would look very nice, re. your question on stretching; have you considered vinyl -noting it stretches more in one direction than the other - depending on the fabric orientation on the back, therefore may be more forgiving than the leather? just a thought...
Jack
Jack
- jk952
Ah yes, the terminology difference threw me off.
I made new door panels etc. with vinyl/leatherette/leathercloth/naugahide? and used a 3M product called "super 77" which seems to be a spray on contact cement - there are also industrial similar products your upholstery person may have access to. Sprayed lightly on both materials, keeping the nozzle back from the material, (instructions from the car upholstery chap - an older Austrian born tradesman- I purchased the material from) then assemble once starting to dry and tacking up which, is quick. If you miss a bit you have a very brief chance to immediately pull it back a bit but not much. It all worked out quite well however. Substrate was thin marine grade plywood for the door panels, side panels, also the rear panel of the seats, etc. I didn't do the "crash pad".
Jack
Jack
- jk952
Heres the chassis out in the air for the first time in about 10 years
And heres the engine coming to meet it
Engine in and carbs on (temporarily ) I want to run the engine before I put the body on to avoid having to take the engine out later
