REV COUNTER CONNECTION
Hi all,
Does anyone have a diagram how to connect the rev counter ?
I do not have a stabiliser and the car is negative earth.
I've seen some discussions mentioning a "loop" can someone clarify this point for me ?
Thanks for your help.
Gino
Milano
Italy
Gino
Milano
Italy
1964 Elan S2 Roadster
1965 Elan S2 Roadster
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1982 Lotus Esprit S3
1961 Ford Anglia
2000 Lotus Elise Motorsport-56
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Third Gear
Hi Paddy and Alan,
Thanks for your comments. I can say for sure it isn't the later type because it is different on the rear.
Does anyone have a photo of the earlier type ?
Gino
Gino
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Third Gear
Does it look like this? This is the original tach from an S2. The loop has to go through in the correct direction. My usual procedure for determining the correct direction is:
1. Take my best guess, install the tach.
2. Observe that the tach doesn't work.
3. Remove tach, put the wire through in the other direction, replace tach.
4. Observe that the tach works.
- Attachments
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
MMMMM..not sure. I'll take a pic tomorrow and post it.
This is for my S3 coup?.
Gino
Gino
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Third Gear
I think a S3 would have the early type, rpm shown as 10 to 80 x 100 on the face. S4 had the later type, rpm 1 to 8 x 1000.
This shows the direction of current flow through the loop. For negative earth the arrows point towards the coil.
Alan.
Alan.
- Attachments
- Tacho loop.jpg (26.53 KiB) Viewed 4379 times
- alan71
Hi Paddy and Alan,
Finally got the photo taken and yes I can confirm it is an RVI type 2402/04.
I have connected the lights up to the unit and work ok.
The is a female connector with two wires coming from it Red/Grey....i need help from here.
Car is negative earth now.
Thanks Gino
Thanks Gino
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Third Gear
Gino,
The brass-coloured fitting on the left side of your photo looks like where the wire needs to loop around. See Alan's blue picture just above.
The wire that loops around here is the one at goes from the ignition switch to the +ve (or "SW") terminal of the coil.
Is the car running ATM? If so, this wire must already exist, but at some point it was removed from the rev counter. You need to see if you can find this wire and see if someone just removed it, or they maybe replaced it with a direct wire from the ignition switch to the coil.
Paddy
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
Hi Paddy / Alan,
Thanks for your replies.
Paddy I'm lost on this ATM, what's ATM ?
Yesterday I tried everything, blew lots of fuses, even tried calling some uk friends but no luck!!
Here's the situation I need to clear up.
I have this loop connection thingy to connect and the diagram I received is self explanatory, but where does this wire start and where does it finish ?
Also I have a male terminal coming off the rev counter what do i need to attach to this ?
I bought this tacho used and sincerely understood it was complete.
Does it matter if I have changed from positive earth to negartive ?
For your help.
Gino
For your help.
Gino
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Third Gear
Gino
What does it say on the front of your rev counter ,it should say positive or negative earth?
Sorry Gino, I should have been a lot clearer.
ATM = "at the moment". I was asking whether or not the car is running without the tach connected.
If it is, then there is already a wire (somewhere) from the ignition switch to the +ve terminal of the coil. (On some coils this terminal is labelled "sw").
This is the wire that must be coiled around the terminal on the back of the tach. Just to be clear, the wire goes from the ignition switch to the coil and *it already exists* - you should not be running a new wire.
The tach also needs a +ve supply, which is what that other terminal is for.
There is some more info, and guidance on conversion from +ve earth to -ve earth here:
http://www.lotus-cortina.com/electric/convert.htm
I hope this helps and sorry for the confusion.
Paddy
Paddy
1963 Elan S1
