Differential gear ratios
PostPost by: Mazzini » Mon May 04, 2020 8:49 am
vstibbard wrote:Ive had S4SE an S3 Se both with close ratio and 3.55 diff fitted and loved them both, the S3 was however a Mike Spence car and made about 135bhp, the S4SE was UK delivered Strombergs with the D type cams and larger inlet valves standard and it had and Ed Winter head job, it made a solid 125bhp on QED's dyno, when Ken Snailham owned it. I assembled the engine, QED supplied parts and Ken ran the engine in and then set it up on the dyno, we adjusted ignition curve, springs and replaced the needles in the Strombergs. The S4 was nicer less fussy down low than the S3 but both terrific to drive and fast.
What happened to your S3? Did you take it back to Australia?
PostPost by: vstibbard » Tue May 05, 2020 2:49 am
I bought the S3 off an Englishman here in Sydney who bought the car over to Australia when he emigrated.
V
PostPost by: TBG » Tue Jul 21, 2020 10:45 pm
3:1 being fitted over the next two days. Please cross all your fingers for me........... :D :D
TBG
PostPost by: TBG » Thu Jul 23, 2020 3:53 pm
Differential.jpg and
Well it is fitted and I have had a shortish blast. It is fantastic. Very very close to the chart above so kindly provided by 1owner69elan. Absolutely no problems pulling away and second and third are amazing. In top I cruise on the French auto routes at about 82mph at about 4650rpm. Those rpm now give me 94!! Checked with a gps speedo. So cruising is MUCH more relaxed and there is still plenty of pull in top. Cost of CWP £430 and what does a five speed cost? Happy bunny! :lol: :lol:
TBG
PostPost by: 1owner69Elan » Thu Jul 23, 2020 5:24 pm
Glad your "experiment" worked out. Congrats on your thinking outside the box.
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: Quart Meg Miles » Thu Jul 23, 2020 11:05 pm
+1 A brave decision and I'm glad our data worked out OK and gave you the confidence to do it! Now enjoy!
Meg
Quart Meg Miles
PostPost by: vstibbard » Fri Jul 24, 2020 3:55 am
Great to hear that, also interesting as it gives the 2.97 ratio boxes a longer first which I always felt it needed, and would be a valid alternative to a change to 2.5 close ratio set.
PostPost by: TBG » Fri Jul 24, 2020 1:22 pm
Just been for a much longer drive and all is brilliant. Yes following a slow car up a long hill now needs third but that is not a problem. No lack of performance around the windy bits of our Somerset roads - great torque in all the gears and on the 303 dual carriageway - so comparatively restful . Absolutely no problem pulling away on very steep slopes. Getting about 21 mph per 100 rpm in top. Oh joy! Now need to get the speedo re calibrated..........off to Speedy Cables in Swansea over the winter. Too much fun at the moment to stop driving..... :D :D
TBG
PostPost by: trw99 » Fri Jul 24, 2020 4:57 pm
Another Euro trip planned, then?
Well done, showed us all the way.
PostPost by: TBG » Fri Jul 24, 2020 7:02 pm
Spot France 2010 (6) resized.jpg and
June 2021 - Alps and Italian Lakes - Yee Haaa!!
TBG
PostPost by: vstibbard » Fri Jul 24, 2020 11:25 pm
It maybe an option for a group order if enough interest.
Vaughan
PostPost by: alanr » Mon Jul 27, 2020 4:53 pm
TBG (Sorry don't know your name.)
Where did you obtain or who did you get to manufacture your 3:0:1 Crownwheel and Pinion?
Currently:-
1971 +2 S130/ 5speed Type 9.
PostPost by: Quart Meg Miles » Mon Jul 27, 2020 10:20 pm
alanr wrote:TBG (Sorry don't know your name.)
https://www.ntgear.co.uk/buy-gears/ was quoted on page 1, Alan, and ntg above!
Meg
Quart Meg Miles
PostPost by: Davidb » Tue Jul 28, 2020 2:53 am
The highest ratio on that site is 3.3:1 which retroford also sells for less money...
I am delighted to hear that this works as well as it does-concerned however that I have a close ratio 2.5:1 first gear.
This is a apparently a much cheaper alternative to the fifth gear options which were sounding very expensive/difficult to fit.
Well done LBG
'65 S2 4844
PostPost by: TBG » Tue Jul 28, 2020 5:52 am
If you speak to Gordon Strachan at NTG company in Arbroath he will do a 3:1 CWP for you. A very helpful chap indeed. https://www.ntgear.co.uk/ Good luck.
TBG
PreviousNext
