What did you do to your Lotus today...
PostPost by: alan.barker » Tue Nov 15, 2022 1:47 pm
I've reread Rohan's write-up on 2000E Gearbox and the Pin i found is the small Interloc one
Thanks Rohan
PostPost by: alan.barker » Tue Nov 15, 2022 5:46 pm
The Pin is the one that goes through the middle selector rail. When i removed the selector rail i had to turn it through 90° pullback and i didn't see it fall out.
PostPost by: SENC » Tue Nov 15, 2022 10:35 pm
You got it!
Henry
69 Elan S4
65 Seven S2
PostPost by: TBG » Tue Nov 15, 2022 10:40 pm
Some clumsy french mechanic has bust the knob on my pull out light switch. I can mend it but how do you get it off the rod? Very simple clear instructions needed as, as Tim will confirm, I am very old!! D
TBG
PostPost by: alan.barker » Tue Nov 15, 2022 11:23 pm
TBG,
there is a little spring loaded pin you need to push in carefully. Then it will come off if your not too clumsy lol.
You can get a new one from rimmer bros "triumph herald".
I bought one for my Sprint. The icon is a little different but only an anorak will notice.
PostPost by: TBG » Wed Nov 16, 2022 8:53 am
Thanks so much Alan - todays job then! D
TBG
PostPost by: trw99 » Wed Nov 16, 2022 1:05 pm
[quote="TBG"]Some clumsy french mechanic has bust the knob on my pull out light switch. I can mend it but how do you get it off the rod? Very simple clear instructions needed as, as Tim will confirm, I am very old!! D[/quote]
Not so old that you can't get into your Elan, though!
PostPost by: ajwheels » Wed Nov 16, 2022 5:36 pm
trw99 wrote:Not so old that you can't get into your Elan, though!
I've found it's the getting out to be the challenge..... :lol:
1966 S3 DHC
45/6261
ajwheels
PostPost by: wolfchen » Wed Nov 16, 2022 8:41 pm
put the top for the winter ,will drive it till the salt fits the roads
wolfchen
PostPost by: reb53 » Fri Nov 18, 2022 5:58 am
Today picked up the now metal sprayed stub axle. NZ$220. Interestingly my records show the same company did the other side in 1986, for NZ$50...!
Whilst waiting I fitted a new hood, and hood cover.
If I was charging I'd charge 3 times as much for fitting the cover.
Ralph.
reb53
PostPost by: reb53 » Sun Nov 20, 2022 4:53 am
Stub axle back into hub and new bearings into both rear hubs.
Diff back in, everything reconnected followed by a successful test drive.
Hopefully a trouble free WOF, ( MOT ), tomorrow morning.
And then ready for Summer !
Ralph.
reb53
PostPost by: baileyman » Sun Nov 20, 2022 12:35 pm
IMG_9491.jpeg and
Took delivery.
baileyman
PostPost by: berni29 » Sun Nov 20, 2022 6:29 pm
Congratulations. Looks like a really fun car.
You took a delivery, and I delivered a chassis out from under my recently purchased "for total restoration" plus 2s.
All the best
Berni
chassis.JPG and
berni29
PostPost by: Mileso » Mon Nov 21, 2022 4:49 pm
Took my door apart to start the replacement of window lift wire! Oh what joy. Wasn't too bad but not looking forward to getting the lock rods back in place..
Mileso
PostPost by: 661 » Mon Nov 21, 2022 6:26 pm
baileyman wrote:
Took delivery.
Lovely
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PreviousNext
