Solution to oil breather on TwinCam and BDA
• Page 1 of 4 • 1, 2, 3, 4
My friend has made another 6 of these breathers. They are an elegant and well engineered solution, are designed to be installed without the removal of the head, and are adjustable.
They work on
Twin Cam (Std and tall block)
BD series of engines.
I have them fitted on my elan T/C and also on a Escort fitted with a BDA
Price is $150.00. (10% less for members) +P&P
Please PM me if you would like to get one
They work on
holywood3645 - Fourth Gear
Only 3 left, if you’re interested speak up!
It will be a while before a new batch will be made.
No! Not elan trickbits design. I did not need to mill either block o my installation.
I just expanded the photo and think I understand now - the bottom o ring is not compressed flat, but slides into the hole in the block yes?
Put me down for one. I’ll mail you for the logistics. But still send me a photo if you can?
Hal Adams
Evora SR
Elan +2
Evora SR
Elan +2
HCA - Coveted Fifth Gear
This is Rob’s design, and solution to the problem. I hope you all appreciate the effort and thought he has put into it. I included the safety wire on both my engines.
James
PM Sent.
holywood3645 wrote:My friend has made another 6 of these breathers. They are an elegant and well engineered solution, are designed to be installed without the removal of the head, and are adjustable.
They work on
- Dan in NJ
- New-tral
This is my home made breather tube which I made and installed when I replaced my S4 water pump in 2018 (the pump had lasted about 20 years).
The machined aluminium tube has twin O-rings at the lower end that seal in the block and one large section ring sealing in the hole in the head which on my car looked to have a fairly rough (drilled) surface. The sliding collar locked with a grubscrew is mainly for axial location but has also has an O-ring that seals both diametrically and on the underside of the head,
Ian
Ian
68 Elan S4 DHC. Built in a weekend from a kit (just like the advert said)
Elanman99 - Third Gear
Users browsing this forum: No registered users and 5 guests
