Side lights.
PostPost by: davidj » Fri Oct 02, 2020 10:18 pm
Ok. A very simple question. I am rebuilding my elan from several boxes of parts and about to fit the side lights. They have bulb shields. Looking at the front of the car, should the shields be above the bulbs, to the left or right? I guess they should not be underneath!. It is a UK car.
Cheers .
Third Gear
Third Gear
PostPost by: ericbushby » Fri Oct 02, 2020 10:24 pm
They should be on the inside to reflect the light outwards.
Eric in Burnley
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: TBG » Sat Oct 03, 2020 10:38 am
Mine does not have bulb shields?............just ultrabright LEDs :D
TBG
Fourth Gear
Fourth Gear
PostPost by: 69S4 » Sat Oct 03, 2020 1:08 pm
From memory the shields are at the top. Agree about changing to LEDs - the old bulbs melted the front lenses on mine. LEDs not only run cool but are about three times as bright so usable as daylight running lights (sort of :lol: )
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: ericbushby » Sat Oct 03, 2020 4:10 pm
Hi Stuart,
You may be right. I am getting confused.
I was thinking about the clear part of the lens which needs to be on the outside. On my car the lamps had been fitted on the wrong sides of the car and I changed them over.
Now I have realised that, I do not see anything which could be called a shield so I am confused again.
Eric
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: oldelanman » Sat Oct 03, 2020 5:02 pm
ericbushby wrote:They should be on the inside to reflect the light outwards.
Eric in Burnley
Eric,
You are quite correct. The Workshop Manual states that the clear portion of the lens must face the outside of the car and because the lugs which fix it to the bulb holder are different sizes, this can only be achieved when the shield is on the inside.
Side lamps.jpg and
IMG_20201003_172925.jpg and
IMG_20201003_172951.jpg and
Just to confuse the issue the illustration in the manual shows the shield at the top which would put the clear part of the lens at the bottom :roll:
Roger
S4 DHC
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: ericbushby » Sat Oct 03, 2020 5:26 pm
Oldelanman,
I would fit that name, I like it. I wonder how I would qualify for it.
Thanks, that clears it up I think, except that mine have no shields.
But with the LED`s it doesn`t matter any more.
Eric
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: saildrive2001 » Sat Oct 03, 2020 6:14 pm
Shields on the inside.
Keith Marshall
69 S4 SE DHC RHD Original owner
saildrive2001
Fourth Gear
Fourth Gear
Users browsing this forum: No registered users and 25 guests
