Another post about uprights / trunnions
• Page 1 of 4 • 1, 2, 3, 4
I have dismantled the front uprights and acquired new trunnions, ball joints and track rod ends. So far, so good. However... on degreasing the kingpin thread on the upright, I have discovered the threads are rusty.
I've read all the stories about them giving way, stress cracks due to pitting, etc and I am very concerned. Problem is, new uprights are so expensive and there is little guarantee of quality. I had read that the GT6 uprights Canley sell are good... but what do you think of these pictures? Would these be considered safe?
JonB - Coveted Fifth Gear
Jon,
Not good news. I would see how loose it is with a new trunion on it. But from here it looks as if it needs to be renewed. Just IMHO.
Are the new one supposed to be that fragile?
- elanman999
- Fourth Gear
I commented on the trunnion fit in my front end overhaul thread. One is OK, the other allows the trunnion to rock left - right on the (vertical) kingpin. I measured about .8mm play although it is tricky to do this. Neither have up/down play which would be an MOT fail.
I have done a ton of reading up on the trunnions, even before getting the Elan, and saw this thread http://www.triumphexp.com/phorum/read.php?8,954741 ? which started out warning people that aftermarket uprights were often manufactured sloppily and there was a danger that they would fail prematurely.
That thread is a long one but the upshot of it is:
All opinion / experience gratefully received!
- The base of the thread should be smooth with no pitting
- The metal used should be of good quality
- The thread should be roller made, not cut (to reduce the risk of micro fractures) and there should be no sharp edges or burrs.
- The oil gallery should be dead centre, drilled straight and (if made to the OEM spec) stepped so that the part closer to the upright is narrower.
- 29072 FRONT VERTICAL LINK - GT6 VITESSE R/H
- 29073 FRONT VERTICAL LINK - GT6 VITESSE L/H
Don?t reuse them; you will see just how bad they are when you get the new ones.
You are however right in scrutinising what are on offer, as there are many unhappy stories about the quality, mainly the fit of trunnions.
Fortunately, I had a full set of new old stock STANPART?s when I did mine and they did not have any of the reported ?faults ? with today?s repros. Point being ? they were always like that Sir ? no they weren?t.
- Craven
Jon,
If you need convincing measure the overall thread diameter top and bottom - you will probably find they are worn tapered. Just checked an old one I have and it's 0.011" smaller at the top and there is the same 0.040" or so rock on the trunnion when assembled that you have found. A new trunnion did not reduce that "slop" so the upright was replaced as well.
Roger
S4 DHC
S4 DHC
- oldelanman
Jon, I can only echo the above comments, don't use em ! Apart from anything else, the rough surface of the thread will wear the new trunnions in short order. My friend had one that looked the same as yours on his Elan when we restored it. I wanted to replace it, but with funds tight, he tried very hard to clean it up & make it as smooth as poss, which left a very small amount of play. It passed it's MOT without comment, but by the next one, after only about 2000 miles, it was in a shocking state, with loads of rocking, & up & down play, & the oil was thick with bronze filings. The upright didn't look any different, but the trunnion threads were significantly worn away. He managed to find a good second hand replacement from Boss motors in Snetterton, complete with a perfect Stanpart trunnion for a lot less than the price of a new upright
Regards, Tim
Regards, Tim
- Orsom Weels
- Third Gear
There should be no signs of wear on them. The front stub axles are two of the most highly stressed parts of the suspension. I replaced my front uprights and stub axles recently-with parts from Canley-and felt much safer after the Visa bill was forgotten...
'65 S2 4844
- Davidb
- Fourth Gear
I have used Canley uprights on three cars. No problems.
Regarding pitting, what you see on the surface is less than what is actually beneath. I scrap any that are pitted. Had a Spitfire let one go in 1975 when parking.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
No no I haven't ordered them yet but the trunnionless ones are too expensive and I am not convinced about the design. I've read arguments for and against.
Put it another way. The uprights on my car are as far as I can tell 43 years old and they have not let go despite being greased and left to rust by the PO, then driven 200 miles by me (unsuspectedly, but well aware of the trunnion design and its weaknesses). So, if I can be sure the Canley uprights are good enough quality, then a pair should see me out nicely if I maintain them properly, which I will.
I think I'm baulking at another 200 quid out the door, but I think my uprights are too far gone. Anyone care to disagree?
Users browsing this forum: No registered users and 11 guests
