wilwood spitfire brake kit- will it fit?
• Page 1 of 1
http://www.motorsport-tools.com/triumph ... 65336.html
They also have a kit for the GT6- the hats look taller on that kit (but they do have a disclaimer that the parts may not match the photo). I emailed them; they didn't know if the kit would fit the elan and suggested I try the forums...
the calipers have dust seals; it looks like it might be a nice setup.
1969 elan DHC
- danwasdahl
- New-tral
[quote="danwasdahl"]http://www.motorsport-tools.com/triumph-spitfire-wilwood-brake-kit-midilite-4-pot-calipers-247mm-discs-p-265336.html
the calipers have dust seals; it looks like it might be a nice setup.[/i think so are they the p16 calipers? higgyuk
- higgyuk
- First Gear
danwasdahl wrote:http://www.motorsport-tools.com/triumph-spitfire-wilwood-brake-kit-midilite-4-pot-calipers-247mm-discs-p-265336.html
try http://www.andersensmith.freeserve.co.uk/brakes.htm regards higgyuk
- higgyuk
- First Gear
You could also try this site mio-engineering.dk
http://www.mio-engineering.dk/index.php?route=product/product&path=41&product_id=53
They have a brake kit with Wilwood calipers that fit the Elan. You can have it with the +2 disk or a ventilated disk depending on your need.
I bought a set with the +2 size disk two years ago and I?m very pleased with the fit, quality and performance. The kit comes with all you need for the installment and is easy to fit.
Jannik
1969 S4-SE DHC
Eat one live toad the first thing in the morning and nothing worse will happen to you the rest of the day.
1969 S4-SE DHC
Jas - Second Gear
I've got similar on mine with Plus two discs. Fantastic mod
.- jon1986eac
- First Gear
Well that depends I guess.
I for one didn?t like the power assisted spongy feel of mine, so first I dropped the power assistance and went for the 5/8? master cylinder and 1144 Mintex brake pads, but that resulted in quite a lot of pedal pressure.
With these Wilwood calipers I get a nice firm pedal and good stopping power without excessive pedal pressure, and I have a weight saving of 1.8 kg pr. wheel.
Jannik
1969 S4-SE DHC
1969 S4-SE DHC
Jas - Second Gear
Jas, Jon- Did you remove the servo and associated hardware with the install?
1969 elan DHC
- danwasdahl
- New-tral
Yes I removed the servo and used the 0.7? master cylinder.
The 0.7? master cylinder is the one used with the servo assisted brakes, the unassisted system uses the 5/8? master cylinder.
Jannik
1969 S4-SE DHC
1969 S4-SE DHC
Jas - Second Gear
danwasdahl wrote:Jas, Jon- Did you remove the servo and associated hardware with the install?
Definitely no servo needed IMO on the Elan. +2 may be different tho. Always good to lose a little weight this time of year too!!
- jon1986eac
- First Gear
jono- looking to lose a bit of unsprung weight; current calipers need to be rebuilt; 26R calipers are expensive
1969 elan DHC
- danwasdahl
- New-tral
• Page 1 of 1
Users browsing this forum: No registered users and 1 guest
