Keep or dump Steel wheels?
Hello,
I would like to put my original steel rims (13x4'5J) back on my Elan S3. I need to have them rebuilt first because they are warped with the balancer. I've read a bit about these light metal rims, which I find well suited to the original look, not to mention the fact that I don't have to adjust anything on the car compared to some aftermarket aluminium rims...
Some people say that despite the unveiling, these rims are no longer really usable (dents that come back after a few miles, chronic fragility). Note that I don't ride on tracks, I only ride on roads for my own pleasure.
Before i spend X on this, i would like to get opinions. Are there people who still ride with the original rims? Have they been rebuilt? Or should I forget the idea, put them in the bin and make the adjustments to be able to ride with my 13x5' minilites? Thanks for your help.
- Niklas777
to get the (probably heated debate) started here are a couple quick thoughts
imho original steel wheels in good condition are perfectly suitable to a full road experience of the elan (i.e. wearing roadworthy tires), and I use mine whenever I get a chance (they do require quite a few weights to balance). Slightly heavier repros have been produced (e.g. via Sue Miller) and are even stronger. Some signs of damaged wheels may be (but are not limited to): heavy warping like due to curb/holes hits, rust, cracks (esp. diametrally from pegs to holes), enlarged peg holes (esp. diametrally)... disclaimer : do you own dilligence to ensure your car is apt to your intended use.
keep it on the road !
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Niklas777 wrote:For information my steel wheels are crack free and the holes are normal.
They are "only" warped...
warped by how much then ? 1mm would probably pass, maybe 2, the bottomline is would they balance or not : you need a competent and patient tire shop to do so (they would probably need to fit an adapter to properly balance KO elan wheels).
S4SE 36/8198
It's hard to tell the exact measures, but all4 of them were warped on the balance machine.
I wonder if it's worth trying to refurbish those wheels...yet that would be my favorite option to avoid any adjustment to the wishbone nut and wishbone itself...
That's such a pitty modern rim manufacturer don't propose 4 1/2 sizes anymore...
- Niklas777
The biggest issue is actually finding someone who can straighten them successfully…..
'72 Sprint
'72 Sprint
- richardcox_lotus
Niklas777 wrote:It's hard to tell the exact measures, but all4 of them were warped on the balance machine.
did you ask Sue if she had stock left - or if there is enough interest when she might commission a new batch ?
http://www.mickmillerlotus.com/parts-wheels.html
no affiliation (just a happy customer)
S4SE 36/8198
richardcox_lotus wrote:The biggest issue is actually finding someone who can straighten them successfully…..
indeed that can be done in some instances, but this is a delicate process (I believe there is a bit of springing over time to account for cold, yet one would not want to heat them up on a wide basis and mess with the behaviour of the steel) - some people also take out the inner portion and weld them on new rims...
S4SE 36/8198
nmauduit wrote:Niklas777 wrote:It's hard to tell the exact measures, but all4 of them were warped on the balance machine.
Yeap, sent her an email yesterday since her website describes such wheels : http://www.mickmillerlotus.com/parts-wheels.html
- Niklas777
I had my wheels straightened by a local wheel repair shop. He was able to straighten the lateral warp out, but the warping eventually returned. I eventually found a good set from another owner via craigslist. They are out there at times.
FWIW, I have posted this before, but it is an interesting story and consistent with apocryphal tales about Chapman and his passion for lightness.
Apparently Lotus approached Rubery Owen (RO) to make the wheels for the Elan, but they refused as they regarded the material specified to be too thin and unsafe. It was only after Lotus increased the gauge of the steel that they agreed to manufacture the wheels. You can find RO stamped on the inside of the rim of the rivetted wheels.
Given the problems with the thicker steel wheels, I would imagine that RO were probably right.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
I've not had a wheel crack in 290,000 miles though I'm not sure if any of the wheels are the originals; I haven't bought one since 1980 when my records start.
Meg
Hi Niklas.
Sometimes a Lotus steel wheel is repairable. What you are referring to as warped may be what I would call `buckled`. It can be done.
The weak point is the part of the centre section between the ventilation holes. This is not strong enough and distortion occurs there. The thicker Sue Miller type wheels solve this problem.
I have straightened a buckled wheel where the rim is still a flat circle and the centre is also flat but not in quite the same plane as the rim.
I had two 20mm thick steel rings cut by the local Laser cutter. He put them in the corner of a much bigger job and charged me a tenner.
Cleaned up on the lathe and drilled they would now ensure that the centre section would not be damaged by the press.
The set up was on a radial arm drill with the dial gauge fixed to the chuck. The press was simply packing pieces, a lever and a large Allen screw. That Allen key is the biggest I have seen (about 20mm across flats)
We pressed the centre section down at one side ten thou` at a time, testing it for run out on the Elan which was alongside the machine.
I now do not know which of the three original wheels I have was the one we straightened. The other two are Sue Miller wheels.
It wasn`t easy but don`t say it can`t be done.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- Attachments
- j2s3031h.png (214.35 KiB) Viewed 972 times
- ericbushby
