Michelin XAS FF
Coker lists these as tubeless tires and yet research from the forum says 13D tubes are required. Is this correct? If so, why? Coker lists a TR13 tube. Would this be an equivalent to the 13D.
https://www.cokertire.com/tires/micheli ... 5hr13.html
https://www.cokertire.com/tires/er12-13 ... -tube.html
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Hi there. I fitted these two years ago and yes they need tubes. Interestingly there is a safety recall in the US but not in Europe.
Best
Best
1967 S3 SE DHC
1970 +2S (RIP - went out in a blaze of glory in 2001)
Stevie-Heathie - Third Gear
Depends on the wheels you are using.
I have them on 5 spoke revolutions without tubes
I believe the original steel wheels don't have the required safety ridge and require tubes, but happy to be corrected.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Stevie-Heathie wrote:Hi there. I fitted these two years ago and yes they need tubes. Interestingly there is a safety recall in the US but not in Europe.
Best
You are correct about the US recall. Only issue is the tires are missing the US “DOT” mark on the sidewall and had not been tested to the DOT standards. So Michelin is performing the test and manufacturing new tires with the required marking. There have been no defects or failures reported.
It's all made clear on here:
viewtopic.php?f=42&t=52221&view=unread&sid=a6c430bbcfe830b29323d5709cd90892#unread
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Phew thank you stress cracks
1967 S3 SE DHC
