Tires or Tyres
PostPost by: Fourducs » Wed Sep 29, 2021 6:42 pm
Just purchased my first Lotus which is a 1969 Elan Plus 2. It needs tires. What tires are recommended? I will not be tracking the car, just polite driving on short hops are planned.
Fourducs
First Gear
First Gear
PostPost by: mbell » Wed Sep 29, 2021 11:47 pm
In the US you have very limited options. Correct size is 165/80r13, options are expensive but very good Michelin xas or cheap Chinese grocery getter only advisable from very limited places.
There more choices in 175/70r13 no particularly good options imo. I run barrum brilliantis that are European made and soft compound. Happy enough with them but might pay for the xas next time.
PostPost by: h20hamelan » Thu Sep 30, 2021 3:21 am
I am running these “tyres” (as I tire easy in my old age) on my +2 with original steel wheels.
https://www.longstonetyres.co.uk/vintage-tyre.html
Original tread pattern, and elivery included in price. Another key point, is they are similar block pattern to rally tyres!
Love your Mother
Earth
PostPost by: The Veg » Fri Oct 01, 2021 2:24 am
Welcome Fourducs! I'm three hours down 85 from you and I have a Plus 2 as well. Can't recommend any particular tire as I'm still on the ones that came with the car, but it's an interesting subject as sooner or later I'll too be shopping for some new rubber.
2012 BMW R1200GS
The Veg
PostPost by: elan+2 » Mon Oct 04, 2021 10:21 pm
You are correct there a few choices here in the US. My plan for my next set is to go with Avon CR66Z's they are about the same price as Michelin XAS and good bit more than Vredestein Sprint's but they really gook the part.
https://www.avontyres.com/en-gb/tyres/cr6zz
http://www.sascosports.com/tires_search ... _diameter=
https://www.cokertire.com/tires/640-700 ... 06552.html
69' Elan +2 50/2520
59' Elite CBU 1157
74' TVR 2500M
elan+2
First Gear
First Gear
PostPost by: 661 » Tue Oct 05, 2021 9:47 am
elan+2 wrote:You are correct there a few choices here in the US. My plan for my next set is to go with Avon CR66Z's they are about the same price as Michelin XAS and good bit more than Vredestein Sprint's but they really gook the part.
The Avon is a corker of a tyre but I use the 185/ under 26R arches. I would suggest the 175 would be pretty tight under standard arches, probably to the point of not fitting.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: elan+2 » Tue Oct 05, 2021 12:22 pm
As the OP stated he is looking for tyres for his +2, a 175 will fit with no issues.
69' Elan +2 50/2520
59' Elite CBU 1157
74' TVR 2500M
elan+2
First Gear
First Gear
PostPost by: 661 » Tue Oct 05, 2021 12:31 pm
:D :D
Graeme
S4 SE
S2 GTS
Caterham 420R
PostPost by: Fourducs » Fri Oct 08, 2021 1:02 am
Thanks to all for your suggestions. I maybe can locate a set of Michelin XAS 165HR13 tires. Interestingly I think XAS's are what I had on my 1971 Fiat 124 Spyder back in the day. Are these tires capable of running tubeless when mounted on the Elan's 13" steel wheels?
Fourducs
First Gear
First Gear
PostPost by: StressCraxx » Fri Oct 08, 2021 2:06 am
Fourducs wrote:Thanks to all for your suggestions. I maybe can locate a set of Michelin XAS 165HR13 tires. Interestingly I think XAS's are what I had on my 1971 Fiat 124 Spyder back in the day. Are these tires capable of running tubeless when mounted on the Elan's 13" steel wheels?
I recently bought a set from Coker Tire. The XAS FF are tube type only. You cannot run them tubeless.
StressCraxx
PostPost by: Fourducs » Sat Oct 09, 2021 12:27 am
I may want to replace two of my 1969 Elan + 2's original 13" steel wheels. Where is the best place to look?
Fourducs
First Gear
First Gear
PostPost by: h20hamelan » Sat Oct 09, 2021 12:58 am
rdent had them
Love your Mother
Earth
PostPost by: Quart Meg Miles » Sun Oct 10, 2021 11:04 pm
Don't be frightened of tubes, I've used them for 50 year and only a couple have failed. I don't trust tubeless on old steel wheels as they aren't always gas tight and a bad hit on a kerb can deflate the tyre instantly.
XAS are expensive in UK so I bought Cinturatos and can't tell the difference from the MIchelins (as fitted to VW Polos) I had before, and I drive fairly hard. I would have thought some of the compact cars in USA would use 165/80R13s. Don't mess around with low-profile tyres as you are driving "politely", enjoy the comfort of the proper size!
Meg
Quart Meg Miles
PostPost by: mbell » Sun Oct 10, 2021 11:17 pm
Quart Meg Miles wrote:I would have thought some of the compact cars in USA would use 165/80R13s.
Not sure if cars did use them but your better than me if you can find them now.
~4 years ago when I got my tires you could order in maybe one or two Chinese brands for daily drivers. I still went for 175/70r13 for the better choice and ability to get a replacement quickly if needed.
When I look now no one offers even one 165/80r13 option, I've checked discount tires, Walmart, tire rack and Firestone and maybe a few others.
PostPost by: jannhall » Mon Oct 11, 2021 3:51 am
Michelin Pilot Sport A/S 3 and Michelin CrossClimate 2 are just some of the options that you can check out. You can check 4wheelonline for other options if you're still looking for a set.
jannhall
New-tral
Next
