KO Spinners Bevel Angle
PostPost by: danielmo » Wed Mar 13, 2019 6:44 pm
Does anyone know the angle of the bevel on the knock-off spinners? Is the angle on the wheels the same?
Dan
danielmo
PostPost by: tedtaylor » Wed Mar 13, 2019 8:12 pm
Do you mean the "mating surface" of the spinner hub nut to the wheel center hole?
The wheel is beveled or curved convex-like. The spinner hub has a flatter, less beveled/curved surface to mate with the wheel. Usually the paint wears away in one very narrow contact band on that mating surface. I don't know that you could give an angle or degree measurement of the beveled surface on the wheel, but perhaps possibly the spinner. I suppose I can get my protractor and estimate an angle in degrees. are you machining something of your own? what exactly are you looking to do?
TED
tedtaylor
PostPost by: el-saturn » Wed Mar 13, 2019 8:19 pm
i could measure the angle, as i DO have the proper instrument, if nobody here has it - presuming you need the angle which you'd use to make yourself a set of KO rims!? sandy
PostPost by: danielmo » Wed Mar 13, 2019 9:33 pm
Sandy,
Thank you.
I am making the wheel centers that the spinners mate up against. The set of alloy wheels did not come with any and they can't mate against the raw aluminum.
Dan
danielmo
PostPost by: prezoom » Thu Mar 14, 2019 12:04 am
On my Plus2, my Nader nuts are engraved "FOR STEEL WHEELS ONLY".
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
On my Plus2, my Nader nuts are engraved "FOR STEEL WHEELS ONLY". So, what makes the difference between the steel wheels and the Lotus aluminum wheels, so far as the knock ons? Why can you replace the steel wheels on a 26/36/45's with Minilites without problems? The knock ons on my S2 do not have any restrictions as to wheel material.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
prezoom
PostPost by: alan.barker » Thu Mar 14, 2019 6:39 am
I have only seen them marked "FOR ALLOY WHEELS ONLY" that's Nader Nuts. For me Spinners with Ears are only for steel Wheels
PostPost by: JonB » Thu Mar 14, 2019 9:01 am
I have spinners with ears on my car, and it is running the original alloy wheels...
PostPost by: elj221c » Thu Mar 14, 2019 11:51 am
danielmo wrote:. The set of alloy wheels did not come with any and they can't mate against the raw aluminum.
Dan
Well, they can and do but I suspect it might depend on the alloy and the depth of the wheel at the centre.
My JAP wheels mate directly to the spinner at an angle of 45 degrees as I remember.
jap-spinner-contact.1.jpg and
spinner-on-jap.jpg and
Roy
'65 S2
elj221c
PostPost by: elanman999 » Thu Mar 14, 2019 12:14 pm
I agree with Roy on the angle as I have just checked a spinner and found it to have an included angle of 90 deg.
I have some Minilite wheels and the nut seats on the alloy of the wheel. Edit:- the nut seats on an alloy insert set into the wheel.
elanman999
PostPost by: tedtaylor » Thu Mar 14, 2019 1:01 pm
the issue of the inserts and metal types has to be one of two things:
1) electrolysis? differing metals creating corrosion by contact, or;
2) metallurgy? differing "strengths" of the different metals not compatible? harder steel crushing weaker alloy?
ok, you scientists and engineers out there......chime in! :)
TED
tedtaylor
PostPost by: alan.barker » Thu Mar 14, 2019 1:35 pm
img_0001.jpg and
On the Lotus +2S Alloys they have these Inserts in the centre of the Wheel for the Nader Nut/ Hexagonal Nut
PostPost by: danielmo » Thu Mar 14, 2019 2:05 pm
Alan,
Thank you for the picture.
The inserts look like they are made of a thin metal, almost stamped. I was designing some that are similar to the ones on the Panasports.
Dan
danielmo
PostPost by: alan.barker » Thu Mar 14, 2019 2:29 pm
Yes, the Inserts are in Stainless Steel. Sometimes you can find them for sale if you're lucky. You need them to be a tight fit in each Wheel where they will stay.
PostPost by: danielmo » Thu Mar 14, 2019 2:33 pm
Alan,
Do you have a measurement for the diameter of the inserts where they mate to the inside of the wheel center? I guess that would be the OD of the insert-able part of the insert(?) where it mates to the wheel.
Dan
danielmo
Next
