Tightening Spinners
PostPost by: lotus98 » Fri Sep 28, 2018 6:26 pm
I have a 1971 Elan and I am doing a track day next weekend
To make sure my wheels stay on before, during and after I have purchased one of those wheel widget things
So my question is what setting do I need to set the torque wrench at? I've only had the car for a month and I'm new to all things Elan!
Many thanks
lotus98
New-tral
PostPost by: tedtaylor » Fri Sep 28, 2018 8:58 pm
150 foot pounds comes to mind, and the exact specification is in the shop manual. Please correct me if I am wrong here.
TED
tedtaylor
PostPost by: 661 » Fri Sep 28, 2018 9:18 pm
I do mine to 300Nm , please check but I think that converts to about 220Lb/Ft
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: JohnCh » Fri Sep 28, 2018 11:44 pm
I just purchased a tool from knockoffspinnertool.com. The instructions state that an early Lotus manual recommends 160-180 ft/lb while a later edition shows 200-220 ft/lb for the octagon (earless) spinners. His recommendation is to compromise at 190 ft/lb.
-John
JohnCh
PostPost by: Concrete-crusher » Sat Sep 29, 2018 7:23 am
Make sure the threads are clean with no trace of grease , you need good friction on the threads
Concrete-crusher
PostPost by: Andy8421 » Sat Sep 29, 2018 8:01 am
Generally tightening torques are quoted for lubricated components.
Does it say in the manual that the threads should be dry?
32 Standard 12
Various modern stuff
PostPost by: oldelanman » Sat Sep 29, 2018 9:24 am
Andy8421 wrote:Generally tightening torques are quoted for lubricated components.
Yes it is stated in the manual and in the S4 driver's handbook which also states that the tapers should by dry. The handbook also gives the higher torque figure of 200 -220 lb ft.
img_20180929_100303.jpg and
img_20180929_100140.jpg and
S4 DHC
PostPost by: Andy8421 » Sat Sep 29, 2018 11:30 am
Roger,
Thank you for this. I'll be out washing the copaslip off my spinners this afternoon.
Interesting that the recommendation is to check the spinners every 1000 miles.
32 Standard 12
PostPost by: Esprit2 » Sat Sep 29, 2018 6:18 pm
No, I disagree. Torque specs generally presume clean, dry threads unless otherwise specified. Some special applications, like rod, main bearing and head bolts/ studs, are always oiled before being torqued. But for a generic engineering table of fastener torques, or for the general torque values given at the end of a Lotus manual's Technical Data Section, the torque values presume clean, dry threads unless otherwise stated. Some engineering tables will give two values, clearly stating which is for dry, and which is for lubed (and 'how' lubed). But if only one value is given with no special clarification, then it presumes clean, dry threads,
I'm a mechanical engineer, and that's what I was taught. However, just to be sure something isn't lost in Brit-American translation, I contacted Lotus and asked about their torque specs. The engineer confirmed that the hardware torque values given in Lotus manuals presume clean, dry threads... unless otherwise stated in the assembly instructions. He also noted that while the engine assembly instructions say nothing about the rod, main bearing and cylinder head bolts/ studs, those fasteners are torqued with oiled threads.
Tim Engel
Esprit2
PostPost by: Andy8421 » Sun Sep 30, 2018 8:00 am
Tim,
Thanks.
I was aware that head bolts/stud torque was quoted lubricated, I thought that applied to all fastenings.
I have always lubricated everything on the grounds I would probably be the next one to undo it. I would guess very few Lotus owners assemble nuts and bolts dry.
32 Standard 12
PostPost by: Esprit2 » Sun Sep 30, 2018 4:19 pm
Andy8421 wrote:I would guess very few Lotus owners assemble nuts and bolts dry.
I hope that's not the case. The friction varies with the type of surface treatment on the fasteners (zinc, chrome, black oxide, etc), but in general something on the order of 50% of the applied torque goes to overcoming friction in the threads and under the head. Only the balance goes to tensioning the fastener. If the threads are lubricated (oil, anti-seize, threadlocker, anything...), then much more of the applied torque goes to tensioning the fastener and can over-stress it, even to the point of yield.
For a lot of general nuts & bolts that you just snug-up without measuring the torque, a little anti-seize isn't a bad thing. But for critical fasteners that you bother to tighten to spec with a torque wrench, read the assembly instructions and be very specific about what you do or don't apply to the threads before torquing.
Beyond the obvious critical fasteners in engines, transmissions and final drives, the most commonly abused fasteners are the bolts/ studs for bolt-on wheels. People tend to slather them up with anti-seize, then torque them to full spec. That's asking for trouble.
Tim Engel
Esprit2
