Michelin XAS and S3 Elans?
PostPost by: BenL » Sat Aug 26, 2017 1:45 am
There don't seem to be many options for 13" tires (tyres). I was thinking of getting a set of Michelin XAS tires. Does anyone have 155R13s on their S3? Coker Tires says that they'll fit an S4, but they don't know if they'll fit an S3 (S3 SE SS FHC to be specific).
https://www.cokertire.com/michelin-xas-155hr13.html
(I tried searching the forum, but there are hundreds of posts with XAS in them)
S3 SE SS FHC
BenL
New-tral
PostPost by: billwill » Sat Aug 26, 2017 6:02 pm
It will depend on how straight is the profile of the tyre.
I know that I changed from 145 to 155 long ago and they rubbed so now I have S4 wheel arches on my S3 coupe body.
PostPost by: Mazzini » Sat Aug 26, 2017 9:10 pm
I run them on my S2 without issue and I run 155 Firestones on my S3, also without issue.
PostPost by: StressCraxx » Sun Aug 27, 2017 12:32 am
When I first bought my Elan in 1979 it had 155/80-13 Pirelli Cinturatos on it. The only place they rubbed was on the top of the front arches when entering a driveway at full lock.
StressCraxx
PostPost by: nigelrbfurness » Sun Aug 27, 2017 8:56 am
Looks like it varies from car to car. I have always run 155s on me Elans and the only problem I ever encountered was once I had one rub on the ARB at full right hand lock. I could never quite adjust it out, either. However, I have always found Michelins a bit too hard for the Elan and very nervous in the wet, the Dunlop SP range suited me better. Recently I have used both Arrowsport and Hangkook tyres on Elans and found them very good.
Nigel F.
nigelrbfurness
PostPost by: dgym » Sun Aug 27, 2017 10:45 pm
I have Michelin XAS on my s3, All fine but for the front right damaging the body on a hard right turn on a bumpy dirt road with two people in the car. So just depends if you're gonna go do a u turn on a dirt road with hardened mud tracks with two people in the car and run over one of the tracks at a very specific angle...
36/6612
1967 S3 Coupe (left the factory in 66)
original rego PPC 8E
original owner B.M. Wetherill ..are you out there?
dgym
PostPost by: BenL » Mon Aug 28, 2017 4:13 am
dgym wrote:I have Michelin XAS on my s3,
Thanks.
dgym wrote:All fine but for the front right damaging the body on a hard right turn on a bumpy dirt road with two people in the car. So just depends if you're gonna go do a u turn on a dirt road with hardened mud tracks with two people in the car and run over one of the tracks at a very specific angle...
I'll keep that in mind (my parents live on a class 3 road that becomes a nearly unpassable Class 4 road (rutted mud) after their house).
S3 SE SS FHC
BenL
New-tral
PostPost by: billwill » Mon Aug 28, 2017 3:04 pm
I don't know if they have changed since, but my recollection of XAS tyre in the early 70's was that there were brilliant in the dry and terrible in the wet; so I've never fitted them since.
